Analyzing Displacement, Velocity, and Acceleration of a Bicyclist in a Park
  • Thread starter Thread starter mimsteel
    Vectors
The discussion focuses on the motion of a bicyclist moving from a position 40.0m east of a flagpole, initially heading south at 10.0m/s, to a position 40.0m north of the flagpole after 30 seconds, now traveling east at the same speed. Key calculations involve determining the magnitude and direction of displacement, average velocity, and average acceleration during this interval. The confusion arises from the change in direction, prompting questions about how the cyclist transitions from moving south to north. Understanding the concepts of displacement and velocity is crucial for solving the problem. The thread emphasizes the importance of analyzing motion in two dimensions to clarify the cyclist's path.
mimsteel
At one instant a bicyclist is 40.0m due east of a park's flagpole, going due south with a speed of 10.0m/s. Then 30.0s later, the cyuclist is 40.0m due north of the flagpole going due east with a speed of 10.0 m/s. For the cyclist in this 30.0s interval what are the A.) magnitude and B.) direction of the displacement, the C.) magnitude and direction of the average velocity and D.) the magnitude and direction of the average acceleration
v=d/t
a=v2-v1/t
not sure where to start really
mimsteel said:
At one instant a bicyclist is 40.0m due east of a park's flagpole, going due south with a speed of 10.0m/s. Then 30.0s later, the cyuclist is 40.0m due north of the flagpole...
I am confused here, how can a person due east who's going south end up in the north?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
