Velocity of a box going up an inclined plane.
A box is launched up a frictionless incline at a 20-degree angle with an initial velocity of 10 m/s. The calculation involves using the equation v = u + at, where gravity's effect needs to be factored in. The initial solution incorrectly used values for acceleration, leading to confusion about the final velocity after 3 seconds. Upon review, the correct acceleration value should have been consistently applied, resolving the discrepancy. The final answer was confirmed to be accurate after correcting the numerical error.
Berean7
A box is hurled up an incline plane of 20 degrees at 10m/second. There is no friction. What is the velocity after 3 seconds. I know gravity and the sin of 20 degrees has to be factored in.
v=u+at. u is initial velocity, v is velocity after 3 seconds, t is time.
9.81x.342=3.355ms^-2. Using the above equation I calculate -.065m/s (10-3.55x3). This does not match any of my answers. I do not know were I went off-track.
Welcome to Physics Forums, Berean7.
I agree with your acceleration. I see that (10-3.55x3) is u+at, but were did that
-0.65 m/s come from?
Check out the two numbers 3.355 and 3.55 in your analysis.
Chet
Good catch, Chet.
I should know better than to answer questions after hours of grading final exams...
Thank you 4 the replies. .355 should have been used in both spots. I just typed it wrong. I arrived at the right answer.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
