Velocity of pulley when spooling line?
The discussion focuses on calculating the required r.p.m. of a housing drum for even spooling of line based on the velocity of a feed-pulley. The relationship between line speed and rotation speed is established using the formula line speed = 2π r f, where f is the rotation rate and r is the coil radius. A servo-controlled drum is suggested to ensure consistent spooling, with the possibility of using a feedback system that monitors the position of a 'bailer arm' to adjust the drum's speed dynamically. This approach aims to prevent 'riding turns' and improve spooling accuracy. Overall, the conversation emphasizes the complexity of achieving even spooling and the importance of precise control mechanisms.
Wallys
Hi.
I have a scenario where I am spooling line onto a hollow housing of given minor and major diameters. The velocity of the line being fed into the housing is determined by a feed-pulley of known diameter and r.p.m. I need to calculate the r.p.m. of that the housing needs to be turned in order to accommodate even spooling. Can someone help.
Do you want the housing (drum?) to have a peripheral speed equal to the line velocity however much line is wound inside the drum? (Is that what you mean by "even spooling"?)
To relate rotation speed to line velocity you can just use
line speed = 2π r f
where f is the rotation rate in turns per second and r is the coil radius.
I guess the best way to ensure this is to calculate the speed needed for the empty drum to fill at the right speed and to operate the drum at this speed. You could use a slipping mechanism to allow the drum to slow down as it fills up. Some sort of fluid drive could achieve this. Otherwise you would need a servo control to match the speeds - using the above formula. Not a trivial problem, though.
Thank you for the reply.
The answer to your first question is, yes. The drum will be servo controlled through a PLC. The drum also has a give width. I therefore need the formula to program the controller.
I have been thinking some more about this. If you are going to have to use a servo then why not use a servo system which actually looks at the position of a 'bailer arm' with respect to the last coil and adjusts the speed / rotation of the drum to get even spooling. This would be a more 'complete' feedback loop than one which makes assumptions about where the line should end up. I appreciate that it may be more difficult to sense position than speed / revolutions but it may be worth considering if the conditions in the drum aren't too 'hostile'.
It would detect 'riding turns' whereas you system would go on regardless.
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
