Veloctiy of image of a moving obect having constant veloctiy
  • Thread starter Thread starter spectrum123
    Constant Image
When an object moves towards an observer with constant velocity, its perceived velocity changes due to the way its image appears in a stationary mirror. As the object approaches, it appears to grow larger at an increasing rate, leading to the perception of acceleration. This phenomenon is explained by the concept of "rate of looming," which describes how the angle subtended by an object increases as it gets closer. This effect is significant in visual perception and is often utilized in cinematography to manipulate viewer perception. Consequently, rear view mirrors can distort the judgment of speed and position of approaching vehicles.
spectrum123
If an object moves towards us with constant velocity, its velocity is constant with respect to us. But when we view its image in stationary car rear view mirror (or any stationary mirror), its velocity is changes? Why and How?
If the mirror doesn't change the size of the virtual image, then it only reverses the image from front to back so that a car approaching from behind appears to be approaching from in front.
For example,A person is coming to you,starting from 1km away(Moving at constant velocity).At first,You would be seeing him getting bigger slowly but as he approaches closer,His rate of getting bigger increases.That's why you think him getting accelerated.
This is associated with vision.If our Field of view were parallel,the person will appear to be in the same size,No matter how far he is.
I need a little clarification of your question.
But i think its velocity is constant with respect to us...
Its due to relative velocity, that velocity appears different with respect to the car or you.
I heard of an expression "rate of looming", which is supposed to be how we judge the rate of approach of an object - this is the rate at which the angle subtended increases and will work better for large objects which subtend a large angle (understandably).
In many circumstances we use this more than binocular vision or perspective clues - which is why the effect is used in cinematography (zooming etc.)and we 'believe' what the director wants us to.
This effect could also be responsible, I think, for the fact that rear view car mirrors are not good at helping us to judge position and speed of overtaking vehicles.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
