How High Can Basketball Players Jump?
  • Thread starter Thread starter Intr3pid
    Vertical
The discussion focuses on calculating the initial launch speed and air time for basketball players with a vertical leap of 120cm. Participants emphasize using equations of motion to derive these values, specifically noting the known variables: displacement (1.2m), acceleration due to gravity (-9.8m/s²), and final velocity (0 at maximum height). The approach involves identifying the appropriate equation that incorporates these variables to solve for initial velocity. The conversation encourages a methodical breakdown of the problem rather than providing direct answers. Understanding these calculations is essential for analyzing athletic performance in basketball.
Intr3pid
the best rebounders in basketball have a vertical leap (that is, the vertical movement of a fixed point on their body) of 120cm.
a) what is their initial "launch" speed off the ground?
b) how long are they in the air?
i don't want you guys to give me an answer. Can you guys point me in the right direction on how to solve these questions?
Think about your equations of motion. What I do is write down the variables that I know, and the variable that I want to know, then find the equation that has all of those in it.
So for this case you know that.
x = 1.2m (displacement)
a = -9.8m/s^2 (accelleration due to gravity)
v = 0 (final velocity, this occurs when they are at maximum height)
u = ? (initial velocity, what you need to find)
So you need to find the equation that uses x, a, v, and u and solve it.
