Very elementaria kinematics question
  • Thread starter Thread starter maria_conchita
    Kinematics
The discussion revolves around a kinematics problem involving a car that travels a quarter mile in 24.1 seconds from rest. The initial attempt to calculate constant acceleration and final speed using the formula for constant velocity was incorrect. Instead, the correct approach involves using kinematic equations that account for constant acceleration, specifically x = Vot + (1/2)(a)(t^2). The importance of distinguishing between constant velocity and constant acceleration is emphasized, as the former does not apply in this scenario. Understanding these equations is crucial for solving such physics problems accurately.
maria_conchita
A car starting from rest travels one quarter of a mile in 24.1 sec.
a) What is the constant acceleration?
b) What is the final speed?
2. The attempt at a solution
The solution is actually given in the book, but before posting that, I want to know why my attempt doesn't give me the same answer.
Here is what I tried:
vf = xf/t
vf = (1/4)/24.1 = 0.01037 mi/s
then:
a=vf/t
a=(0.01037 mi/s)/ 24.1s = 0.000430 mi/s^2
The way the author found the unkown was using other kinematic equations:
1) x = Vot + (1/2)(a)(t^2) where Vot = 0. To find the acceleration
2)Then with that they find "Vf" by Vf= Vo + at
I've just started to learn physics by myself and I knew it was going to be hard but I wasn't expecting getting stuck in simple problems like this one so please be patient and help me out. Maybe it's just some logic I'm not getting.
Thank you!
Eva
The equation v = x/t only works with constant velocity. For non constant velocity but constant acceleration, you can use the equation x=v0t + 1/2at^2. The 4 kinematic equations for constant acceleration can be easily derived using calculus.
x=v0t + 1/2at^2
v-v0 = 2ax
a = (v-v0)/t
v = (x-x0)/t
The last 2 are for average values of acceleration and velocity
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
