Very simple question regarding work and energy transfer
80 replies · 18K views
selftaught said:
You'd be arguing against an entire scientific discipline.
It is more likely that I am arguing against your misunderstanding of an entire scientific discipline. But if you are correctly understanding the discipline then the discipline is in error. It will not be the first time.
selftaught said:
The reference to 'exposure' proves problematic, as you can see, when explored.
Exactly, which is why you should try something else.
selftaught said:
And in this one paragraph you've uncovered my dilemma. 'Transferred' - explain that in terms of energy and landing from a fall. Force is involved in impact, and KE is pre-impact.
A falling body's energy is maximum at the top of the fall, energy has been transferred to it by the elevator. During the fall there is little or no energy transfer at all. Assuming a rigid surface almost no energy is transferred to the ground and the injury is maximum. Assuming a very soft surface a large amount of energy will be transferred to the ground and the injury will be a minimum. In either case the ground does not transfer energy to nor do work on the body, the body transfers energy to and does work on the ground, resulting in a reduction of injury. The energy transfer theory is not very successful here.
selftaught said:
Given the definition of injury in terms of energy exposure, exchange, or transfer, I'm then attempting to reconcile any impact explanation with the initional pre-impact injury causeing energy.
And you are having difficulty in that reconciliation because the definition is fundamentally bad.
Rap said:
I modified myself on that - In the special case of an infinitely massive, perfectly rigid (hard) Earth, the Earth has the capacity to do work on the bowl without the Earth deforming. In this case, the Earth exerts a force on the bowl, but absorbs no energy. If the bowl emits no sound as it breaks, and after the collision, the bowl pieces are motionless, then you know, by conservation of energy, that the work done by the Earth on the bowl is equal to the kinetic energy of the bowl when it first touches the Earth, and all of that energy has been converted to heat, because there is no longer any kinetic energy. The work that was done is the result of the force by the Earth acting on the bowl.
Specific questions.
1. 'The Earth has the capacity to do work'. Energy is defined as the capacity to do work. What form of energy does the Earth have which then has the capacity to do work?
2. I understand the idea that the reaction force applied by the Earth causes displacement in terms of deformation of the bowl. The recently introduced idea that work done on one object is mirrored by work done on the other object causes me a problem. The bowl applies a force on the earth, but there is no displacement. No displacement, no work according to the most basic of texts. ... Or is that the answer. The displacement of the Earth as a result of the work done on it by the bowl is so infintessimal as to approximate zero displacement.
... bugger, if so, I still come back to, if the Earth does work on the bowl it transfers energy. What energy?
Crowell just threw a spanner in the works in emailing me now that 'work is done on the ground.'
Rap said:
Now comes the hard part - What are the processes by which the bowl's kinetic energy gets converted to heat? This is what we should concentrate on.
No, no, no. That's not what I'm interested in. It may be of generic interest but I'm focussed on energy and the transfer of energy to cause damage only .
"In either case..." - this is not correct. On a soft surface the object pushes into the soft surface which absorbs energy, then rebounds, transferring energy back to the object. In either case, the ground DOES do work on the object, or else its energy would not change. Finally, assuming a rigid surface, the body transfers no energy to the ground, and does no work on it. It exerts a force on the rigid surface, but since the rigid surface does not move, the dx in the equation W=F dx is zero and the work is zero. Looking at it another way, the rigid surface absorbs no energy, and so no work has been done on it.
Not a lot of room to misunderstand. One of the fundamental breakthroughs of injury science was James Gibsons identification of energy as being the 'agent of injury' in 1961. William Haddon can to the same conclusion independently 3 months later and clarified some confusion surrounding Gibson's explanation by including a vehicle of vector that conveyed the agent of injury, energy.
Can't. Given the definition of injury. If there was a definition that said injury was caused by the application of momentum or something else, all good, but to structure an argument I need support.
Welcome to my world.
BTW, thanks for taking the time to help me with this problem.
The quick answer is that energy is NOT defined as the capacity to do work.
That is the answer. The recently introduced idea does not assume a rigid Earth (or floor). If the Earth is perfectly rigid, then no work is done on the Earth.
For a rigid Earth, it does not transfer energy, it exerts a force. This force acts on the body causing it to convert its kinetic energy to heat energy, but it does not transfer any energy. The rigid Earth absorbs no energy, and has no energy of its own, so there is none to transmit.
No spanner, he is simply saying that the Earth is not perfectly rigid and he is right, it is not. There is no such thing as a perfectly rigid body. That does not mean that we cannot pretend it is rigid. If it is close to rigid, we will get results that are close to the truth. Send him your quote and this response, I believe he will agree.
Quite honestly, I don't know where to go from there. I can quote numerous texts which describe energy in exactly these terms. McGinnis, Biomechanics of Sport and Exercise, 'in mechanics,energy is defined as the capacity to do work' (p105). The same in Hall, Basic Biomechanics, p 408. Carr, Sport Mechanics for Coaches, p44. Whiting and Zernicke, Biomechanics of Musculoskeletal Injury, p56. I quote these because these are the texts open on my desk for the past week or two while I've tried to come to grips with this issue. Then there are the large number of other texts that I've referred to that define likewise.
That has been my position all along.
My apoligies. My cut and paste was shoddy. What Crowell said was 'No work is done on the ground' in the case of a body impacting with the ground. No work done on the ground by the body means, according to Crowell and agreed to here by I can't remember who, no work done on the body by the ground. Thus work does not get done.
In this case, what I think I'm left with is that upon impact no work is done, therefore no energy is transferred. The damage is explained in that the KE is not transferred but retained in the body and converted into sound, heat, electrical, etc energy resulting in deformation, permanent deformation, and/or damage. A force has been applied by the body and the ground has applied a reaction force, and since there was no change in energy in the ground no work has been done.
Now, if this is correct, all I've got to find is support for this argument as there are a number of texts which refer to the damage to body and car from an impact with a solid object or Earth as being the cause of work done on it. Unless, ... I read one text which explained that 'scientists' used the terms transfer and transform to refer to the same thing. In this case, if transfer is used to refer to transfer from one form to another, the 'work done' is the transfer of KE to the other form of energy in the body. Of course I run into the problem of identifying the agents of force and reaction force in this case, given work is done on both agents.
... my head is hurting. I'm done for a while. Cheers. Thanks for the help.
Instead, the KE is converted to sound, heat, and electrical energy (ignoring for the moment such specialised concepts as crystals and large area or whatever) the results in deformation, permanent deformation, and damage in the fallen body.
The definition is clearly wrong.
I don't know James Gibson's background, but William Haddon was a MD, not a physicist. A MD's training is focused on medicine and not physics, and thus as a group their grasp of physics is loose at best. If you want to use that kind of loose interpretation of physics then don't expect to be able to do the kind of rigorous analysis that you seem to want, it simply won't work.
selftaught said:
OK. A completely different response received from Ben Crowell (physics professor).
'In the example of the fracture, the energy is going into electrical potential energy to separate, e.g., one calcium atom from another.'
Just when I'm coming to grips with the conversion of KE to sound and heat energy when damage is inflicted on a body from a fall. ... Arghhhhhhhhh!
I mentioned fracture in Post 15.
Ah - it says "in mechanics, energy is defined as the capacity to do work". This is not generally true. In thermodynamics, energy cannot be totally converted into work, so this definition fails. And we are doing more than mechanics here, we are doing thermodynamics, because we are dealing with heat. Maybe it would be better to think of kinetic energy or potential energy as the capacity to do work, but not heat energy.
Yes, that is true, but in the rigid Earth case, the body does work on itself. Please, let's consider a simple problem, where we know exactly what is going on, and watch what happens to the energy. If you don't understand this simple problem, then let me know, don't just skip over it or ignore it. Take a mass connected to a spring to its right, moving to the right, towards a rigid Earth. Let's say the spring can be compressed, but it will not expand, so that you can add energy of compression to it, but you cannot extract it. Some kind of racheting mechanism or something. When the spring touches the Earth, it exerts a force on the Earth, and the Earth exerts an equal force back. The spring compresses. The Earth is doing no work on the spring, because, on its end of the spring, there is no motion. The spring is not doing any work on the Earth, again, because there is no motion there. The amount of work done is dW=F dx and dx is zero. Work IS being done on the spring, by the moving mass however. It is exerting a force on the spring, equal and opposite to the force the spring exerts on it. Here, there is motion, dx is not zero, the kinetic energy of the mass is being transferred to the spring. When the spring reaches its maximum compression, the velocity of the mass is zero. But there is no rebound, because the spring cannot expand. So now the total original kinetic energy of the mass is bound up in the potential energy of compression of the spring, and nothing is moving. (Please note that I was wrong when I said the rigid Earth did work on the object)
Now you can extend this to the complicated case - For a rigid Earth, no work is done by the ground on the object, no work is done by the object on the ground, but different parts of the body perform work on different other parts, the net result of which is to convert almost all of the original kinetic energy of the body into heat.
Yes.
I think that from looking at the above example, you can see that there are two systems, the mass and the spring, and the kinetic energy of the mass is transferred to the potential energy of the spring. This could also be thought of as a transformation of the mass-spring system.
Perhaps we are looking at this the wrong way. Think of the body, or any object really, as not 1 object, but LOTS. Think of it as it's composite particles. In this case it is easy to see how an arm can exert work on the bone causing it to fracture. If you look at each individual spot in the body, you can see where they are getting their energy from, what is doing work on them, and the result of that work. Add it all up into a macroscopic effect and you get injuries.
potential energy plus the kinetic energy of a system is always the same, which can be accounted and assumed as zero. systems such as springs have a point in which the velocity is at its highest I think is called the eqaulibrium point. the points in which the spring reaches a maximum before stopping contains the highest potential energy and the highest force and highest acceleration. there's also the concept of work-kinetic energy theorem where work is transferred as kinetic energy is released, considering that velocity is constant. so, I hope you understand a little bit more. What are you confused about exactly?
sorry not zero, but the kinetic energy plus the potential energy is constant.
One other problem with energy as the fundamental mechanism of injury is that energy is frame-variant and the extent of injury is not.
I think this will not cause confusion. It will complicate the calculations, but not change the outcome. Just pick the simplest frame of reference (Earth stationary) and you can be certain that transformation to any other frame will modify the energy bookkeeping, but not the conclusions.
That is just it. If energy were the sole cause of injury then because energy is frame-variant you would expect that injury would also be frame variant. But of course that is absurd, changing coordinate systems cannot possibly change the outcome, as you say. Therefore the inescapable conclusion is that injury is not merely due to energy.
Actually, I think that the best chance this idea has is to require that energy be defined in the body-stationary frame. In that frame the surface exerts a force on the body and as the body deforms it moves, so work is actually done on the body in this frame. Also, in the body-stationary frame the work done by a rigid surface is actually greater than the work done by a soft surface which corresponds with the greater injury. Of course, this frame is non-inertial.
I think that concluding that the injury is not due to energy is (practically) wrong. Its all a matter of bookeeping.
The bottom line is that, to do the problem very accurately, you have to use both conservation of energy and momentum. You have to assume that the Earth has finite mass.
If you use a frame where the Earth is initially at rest, then the only energies are the objects initial KE due to its velocity V, its final heat energy Q, its final KE (very small) and the Earth's final KE (very small). All the very small parts are not what we are interested in, so we can discard them. The momenta we have to deal with is the objects initial momentum, its final momentum (very small) and the Earth's final momentum. So that's easy, the initial momentum of the object gets transferred to the Earth and forget about the small stuff.
If you use an inertial frame where the object is initially at rest and the Earth is moving towards it at velocity V, then the energies are the initial KE of the object (zero), and the initial energy of the Earth (very large). The final energies are the KE of the object, the heat energy Q, and the KE of the Earth (very large). The final energies are the KE and Q of the object, and the KE of the Earth (very large). The initial momentum is just the momentum of the Earth (very large). The final momenta are the momentum of the object and the final momentum of the Earth (very large). Now we have a bunch of very large quantities that we are not interested in mixed in with the quantities that we are interested in.
This complicates things because now we have to watch the very large quantites closely, we cannot ignore them. We cannot assume the mass of the Earth is infinite, we cannot assume its initial and final velocities are the same. It complicates the bookkeeping and is not a good idea.
We definitely don't want to go to an accelerated frame of reference. Not only will we have all the problems listed above, but we will have to come up with a virtual force field to explain why inertial objects seem to accelerate.
Right, but in the Earth's frame energy transfer does not explain the injury since no energy is transferred (rigid surface). So despite the extra complications, you simply cannot use the "usual" frame if you want to equate energy transfer to injury.
Also, in biomechanics a body's rest frame, or even the rest frame of a single bone, is often used. So many people involved on the technical side of this field are familiar with non-inertial frames.
Right, no energy is transferred from the Earth. It is the kinetic energy of the object which is transformed into heat as a result of the force applied by the Earth.
I think in this case we do not want to use huge numbers such as the mass of the Earth. If we stay in the body frame, we have to invent a force field which explains why the Earth decelerates from V to zero during the time of the collision. I don't think we want to do that either.
This is the key point. There is an injury, there is no transfer of energy. Therefore, in the Earth's frame the transfer of energy is not the cause of the injury as asserted by the OP.
Ah, I see what you are saying, and that is interesting. In the Earth inertial frame, there is no transfer of energy from the Earth, while in, let's say, the inertial frame of the object when it first touches the Earth, energy is transferred from the Earth to the object.
That means that the question of whether energy is transferred from the Earth is frame-dependent. I think that to do it properly, in any frame, the conservation of momentum must be included, so in that sense you are right, its not a matter of energy alone, its a matter of energy and momentum. Let me rephrase to say that the bookkeeping math for energy and momentum are simplest in the Earth inertial frame, where it happens that (practically) no energy is transferred from the Earth, and (practically) all of the object's initial momentum IS transferred to the Earth. Does that sound right to you?
Yes, exactly.
Agreed.
