Very Trick laplace Transform Q
matt222
solve the following differential equation using laplace transform:
dy/dt+yx=0
y=20 when x=0
I took the laplace for each term
L(dy/dx)= s*Y(s)-y(0)
L(xy)=X(s)Y(s)
subtitute back to the equation,
s*Y(s)-y(0)+X(s)Y(s)=0
s*Y(s)-20+X(s)Y(s)=0
Y(s)=20/(s+X(s))
I got until here aand in point of view it will not be solved
<is it what I did and what I said is right
same with cos(y)*dy/dt-1/t=0, y=pi/4 when t=1 it wony be solved using laplace, is it true
dy/dt+yx=0
y=20 when x=0
Do you mean \frac{dy}{dx}+xy=0[/itex] ?<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> <h2>The Attempt at a Solution</h2><br /> <br /> I took the laplace for each term<br /> L(dy/dx)= s*Y(s)-y(0) </div> </div> </blockquote><br /> Assuming you are transforming from the x-domain to the s-domain, that is correct.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> L(xy)=X(s)Y(s) </div> </div> </blockquote><br /> No, that&#039;s not how you take the Laplace transform of a product of two functions.<br /> <br /> \mathcal{L}\left[x^n y(x)\right] = (-1)^n \frac{d^n}{ds^n}Y(s)
L(xy)=-dY(s)/ds
so now we have s*Y(s)-y(0)-dY(s)/ds=0
so now we have dY(s)/ds-s*Y(s)=-20
now by using integration factor
assume
p=-s
Q=-20
uY(s)=intgeration(u*Q)
u=exp(-s^2/2)
so u* Y(s)=integration(exp(-s^2/2)*-20))
Y(s)=40+exp(s^2/2)*c
back to x domain it will be really hard
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
