Very tricky double integration problem
  • Thread starter Thread starter jcook735
    Integration
The discussion revolves around a double integration problem involving the integral of a rational function over a specified region. The original poster attempts to evaluate the integral ∫∫((5x)/(x²+y²)) dA, with the region R defined as [1,4] x [0,1].
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods of integration, including U-substitution and integration by parts. The original poster describes their attempts to evaluate the integral, expressing confusion about specific steps in the process. Others suggest alternative forms for the integrand and clarify the transformation of terms during integration.
There is ongoing dialogue about the correctness of integration steps, with some participants providing guidance on how to approach specific integrals. Multiple interpretations of the problem are being explored, and while some progress has been made, there is no explicit consensus on the final outcome.
Participants note that the integral is definite, which may influence the evaluation process. There is mention of a potential oversight regarding parts of the integral that may have been omitted in earlier posts.
jcook735
Calculate the double integral.
∫∫((5x)/(xsquared)+(ysquared)) dA, R = [1,4] x [0,1].
Find the value of the integral.
Well I tried the integral starting with x and then starting with y and couldn't do it either way. Ill show the method using x first. To start off I tried using U-substitution to be able to integrate according to y. I had u = x^2 and du=2xdx. I pulled the 5 out of the equation, then put u in place of x^2 squared at the bottom of the equation, then put a 2 in the equation and a .5 outside the equation so i could replace 2xdx with du. So i ended up with the equation (5/2)∫du/(u+y^2). I then took the integral so that I ended up with (5/2) ln|u+y^2| (evaluated from 1 to 4). I then plugged in x^2 for u. So then I plugged in 4 and 1, and got ∫{(5/2)[ln|16+y^2| - ln|1+y^2|}dy. So then I set it up for the integral according to y. I used integration by parts on ln|16+y^2|, and got stuck. I found u=ln|16+y^2| and dv to equal dy. Then I found du to equal (2y)/(16+y^2) and v to equal y. I then plugged this into the given formula, vu-∫vdu. This is where I got stuck. How do I take the integral of vdu, aka (2y^2)/(16+y^2)? Help would be greatly appreciated.
hi jcook735! :smile:
(try using the X2 icon just above the Reply box :wink:)
that looks pretty good so far!
ok, you need to integrate 2y2/(16+y2)
just write it 2 - 32/(16+y2) :wink:
(the second part is a trig integral)
For your last question, 2y^2/(16 + y^2) = 2 - 32/(y^2 + 16)
oh haha my bad I didnt know you could do that. why does y^2 turn into 32??
OH! I got it. Thank you guys so much :)
can yall check to make sure i did my integration correctly? for the equation you gave me, I should end up with 2y - (1/2)arctan(y/4), correct?
You need to write it out more clearly if you want people to check it. :wink:
But anyway, wasn't there an integral of something over (1 + y2) also?
Also, since this was a definite integral, you should end up with a number.
tiny-tim - That integral of something over 1 + y^2 was probably what turned into the arctan part.
alright my bad. I am taking the ∫2- 32/16+y2.
first, i separated the parts, so I have ∫2 - ∫(32)/(16+y2).
The first integral is 2y.
For the second integral, i pulled 16 out of the bottom, so i had (32)/((16)(1+(y/4)2)). I canceled out the 32 and 16, so i ended up with (2)/(1+(y/4)2). So then its 2∫(1)/(1+(y/4)2). This should turn out to be (8)arctan(y/4), correct?
So the whole equation should be 2y-(8)arctan(y/4).
That looks ok, but it was the whole thing that was bothering me :redface:
you had " ∫{(5/2)[ln|16+y^2| - ln|1+y^2|}dy " in your first post, and the second bit seems to have gone missing.
Oh well I just needed help on the first part cause the second part followed suit. I got it right thank you both very much!
Cool nice job!
  • · Replies 27 ·
  • · Replies 16 ·
