VFD for powering a car lift
  • Thread starter Thread starter Guineafowl
Guineafowl
TL;DR
My 3-phase car lift, currently powered by a rotary converter, is struggling to lift at full capacity. Would a VFD improve things?
Power supply to the 7.5kW rotary is 1ph, 240Vac. Supply voltage drop at full load is within 5%.
The rotary outputs (roughly) 415Vac 3ph to the screw-type car lift, capacity 2.7 tonne.
The lift motor is a 3.5kW, 50Hz, 4-pole, asynchronous induction motor with a power factor of just 0.65. Phase continuity and insulation resistance are good, and the windings look like new. Bearings replaced.
The set-up works just fine, except when lifting my friend’s RR sport, weighing around 2.6 tonne. The motor often stalls and we have to drop the car down and start again. Note that the same motor size is specified for the larger, 3.2-tonne version of the lift.
Voltage drop between rotary and motor is minimal. However, at the motor, when lifting my 2-tonne car, one phase drops from 415V to 350V. The others are not so bad. The motor is pulling 9.6 - 13.5 amps per phase, higher than its plated FLA of 11A.
Options:
1. Larger rotary converter. VERY Expensive and not justifiable for one particular car.
2. Gear the drive pulleys down. The motor pulley is very small, and the screw pulley very large. Space is limited and belt contact is already borderline.
3. 6-pole motor. Expensive.
4. 3ph-3ph VFD between rotary and lift motor. A friend on an engineering forum has offered a 7.5kW one for a price that makes it worth a shot.
My hope is that the VFD will help with the inherent phase imbalance of the rotary, perhaps also with the poor power factor of the motor. It offers V/F control and torque boost as well. Finally, I’d like to experiment with speed control, on the basis that, roughly speaking, operating a little under 50Hz will be in the ‘constant torque’ range of the motor, while slowing down the mechanism to reduce loading.
Link the the VFD manual: https://www.sakobpq.com/resource/attachments/e0b4d2b3f3b946e7827e3247c770f867_17.pdf
Thoughts appreciated.
VFDs can be configured to be powered with single phase. Seems a bit silly to run a VFD off of a rotary phase convertor. The VFD will have a tendency to do the same thing that you are seeing now and that is one phase voltage sagging.
How is your current rotary convertor set up? Do you have capacitors wired between the manufactured leg and either of the others? How is this convertor started? Are you using a transformer to step up the voltage after the convertor or are you relying on the windings in the idler motor to function as an autotransformer? A well set up convertor should do what you are asking it to.
I would not feed the main power for your lift anything except the line frequency it was designed for. The three phase motor that actually does the lifting may get along just fine but control circuits will not.
This one is a 3ph 400V in and out model. Can’t be changed. Cheap enough for a punt on this problem; if no go, I can use it for something else. It’s not worth buying a 1ph 230V in, 3ph 230V out model for this one car - it would have to be specced a lot higher than the 3.5kW, given the lift application with its nearly locked-rotor starts.
The rotary is a commercially-made one for which I don’t have the wiring diagram. All the capacitors are in spec and there is a beefy 240V-415V transformer at the front end. The idler motor is a huge cast iron 7.5kW running in 415V delta (for star-delta starting in other applications).
I think there might be two main problems:
1. The rotary output is not perfect 3ph - unbalanced and perhaps not 120deg apart?
My hope is, the VFD will iron out all this and produce a ‘better’ output. I assume if the phases are unbalanced, this has an effect on the rotating mag field, and torque.
2. The lift motor is very small for the quoted power - no cooling fan or fins, only 0.65 pf, 30% duty cycle.
The VFD may help with that awful power factor. As you point out, the converter should easily do the job, but perhaps the reactive current is loading it down too much.
Edit: one last point I should make, is that good VFD and phase converter makers often ask on their websites that the customer ring them before ordering, if the unit is to be powering a car lift. So it seems to be a special case, perhaps because of the hard starts.
Motor plate, for interest:
Changing from a rotary converter to a VFD will not reduce the circulating reactive current due to the low PF.
1. First, clean and lubricate the screw(s) and nut(s). Lower the friction coefficient with a better lubricant.
2. Maybe if you place a delta of capacitors across the 3PH motor, you can bring the PF closer to 0.95. Do not overcompensate the inductance of the motor.
1. Done - it has automatic screw lubricators which have been cleaned out and topped up.
2. Yes, certainly something to try. I assume 3 equal values of capacitance - start at 5uF?
As I understand it, the motor is custom-designed to be used for minutes in the hour (pf not a priority), but must be able to dead-lift a 3.2-tonne car. The huge current draw from these factors is causing a power delivery problem, not so much a lack of power available.
I would like to experiment with the VFD, seeing as it’s coming anyway. For example, I notice from the motor plate that running at 60Hz boosts the pf to 0.82.
Measure the positive reactance of the motor at operating frequency. Then provide negative reactance to cancel most of that.
As a first attempt, looking at the motor plate (connected in star):
$$Z=\frac V I = \frac {400} {11} = 36.4\Omega$$
Find capacitor with Xc of that value at 50Hz:
$$ C = \frac 1 {2\pi f X_c} = 87\mu F$$
I don't know the details of the VFD that you're considering, but:
Reducing the output frequency would be (approximately) the torque equivalent of option #2 (gear down). Worth a shot, I think.
VFD manual should be linked in the first post. Yes, I thought lifting the car slower might reduce the loading of the system. Or, running at 60Hz might improve the power factor, according to the motor plate. All doable with a twiddle of a pot.
It seems very inefficient. Lifting a 2-tonne car at 30mm/sec only needs around 600W. All the rest of the draw, which is near enough 5kVA, seems to be friction and VARs.
The impedance of the motor is; Z = R + j X.
You should not try to neutralise the in-phase real power component.
Ok, so a cosphi of 0.65 gives an angle of 49.5 degrees:
$$Z=36.4\Omega <49.5° = 23.6 +j27.7\Omega$$
$$C=\frac 1 {2\pi f 27.7} = 115 \mu F$$
Simply put, the convertor is not optimized for the load. A wiring diagram for the convertor would be helpful. You will have the same voltage imbalance when powering the VFD with the convertor. Rotary convertors are optimized for a specific load. Capacitors are chosen to balance voltages and when the load changes the voltages will no longer be balanced. This is the case even if the the convertor is optimized for a heavy load and the load is lightened. The convertors I've been around were using wye wound idler motors. I'm wondering what the circulating currents are within your delta wound idler at various loads.
Could you post one or more pictures of the mechanical part of the lift?
Perhaps we can spot a source of high frictional loss.
The screw is on the right, and turns the other screw via two 90deg gearboxes and a driveshaft under the lift area. The lift nut is no. 19 and it lifts the squarish bracket (12), which in turn lifts the carriage with the arms that contact the car (not shown). Above all that is the autolubricator (8-11).
Number 21 is a safety nut, which normally carries no weight, but is there in case the main nut strips. If this happens, the linkage releases pawl 14 which engages with a stop on the column, preventing the car from being lifted.
I’ve renewed the phosphor bronze lift nuts and nylon carriage slides, and generally given everything a strip and clean/lube. I can turn the whole mechanism (unloaded) by hand via the screw pulley - it’s not easy but I wouldn’t say it’s binding. The screws do get hot in use.
It is an inefficient machine, but I guess this doesn’t matter since it’s only running for seconds in the hour. The manual specifies a 7.5kVA supply, presumably related to this and the huge inrush required when lifting a car already partway up.
Re: inrush - the single phase side of the supply needed a 32A C-curve MCB, rather than the typical B-curve. Under UK regs this is fine, provided the circuit loop impedance is low enough to ensure tripping within the required time (which it was).
The heating could be induced by the thread profiles of screws and nuts not perfectly matching, as when new.
If that is the case, extreme-pressure (EP) grease containing molybdenum disulfide may help.
Some load-induced misalignment could also be forcing the nuts not to work perfectly in line with the screws.
To test that, I would release all the screws anchoring brackets 12 to the lift just enough to slide or rotate a little respect to each other.
  • · Replies 36 ·
14K
