VFD for powering a car lift
  • Thread starter Thread starter Guineafowl
Guineafowl
TL;DR
My 3-phase car lift, currently powered by a rotary converter, is struggling to lift at full capacity. Would a VFD improve things?
Power supply to the 7.5kW rotary is 1ph, 240Vac. Supply voltage drop at full load is within 5%.
The rotary outputs (roughly) 415Vac 3ph to the screw-type car lift, capacity 2.7 tonne.
The lift motor is a 3.5kW, 50Hz, 4-pole, asynchronous induction motor with a power factor of just 0.65. Phase continuity and insulation resistance are good, and the windings look like new. Bearings replaced.
The set-up works just fine, except when lifting my friend’s RR sport, weighing around 2.6 tonne. The motor often stalls and we have to drop the car down and start again. Note that the same motor size is specified for the larger, 3.2-tonne version of the lift.
Voltage drop between rotary and motor is minimal. However, at the motor, when lifting my 2-tonne car, one phase drops from 415V to 350V. The others are not so bad. The motor is pulling 9.6 - 13.5 amps per phase, higher than its plated FLA of 11A.
Options:
1. Larger rotary converter. VERY Expensive and not justifiable for one particular car.
2. Gear the drive pulleys down. The motor pulley is very small, and the screw pulley very large. Space is limited and belt contact is already borderline.
3. 6-pole motor. Expensive.
4. 3ph-3ph VFD between rotary and lift motor. A friend on an engineering forum has offered a 7.5kW one for a price that makes it worth a shot.
My hope is that the VFD will help with the inherent phase imbalance of the rotary, perhaps also with the poor power factor of the motor. It offers V/F control and torque boost as well. Finally, I’d like to experiment with speed control, on the basis that, roughly speaking, operating a little under 50Hz will be in the ‘constant torque’ range of the motor, while slowing down the mechanism to reduce loading.
Link the the VFD manual: https://www.sakobpq.com/resource/attachments/e0b4d2b3f3b946e7827e3247c770f867_17.pdf
Thoughts appreciated.
VFDs can be configured to be powered with single phase. Seems a bit silly to run a VFD off of a rotary phase convertor. The VFD will have a tendency to do the same thing that you are seeing now and that is one phase voltage sagging.
How is your current rotary convertor set up? Do you have capacitors wired between the manufactured leg and either of the others? How is this convertor started? Are you using a transformer to step up the voltage after the convertor or are you relying on the windings in the idler motor to function as an autotransformer? A well set up convertor should do what you are asking it to.
I would not feed the main power for your lift anything except the line frequency it was designed for. The three phase motor that actually does the lifting may get along just fine but control circuits will not.
This one is a 3ph 400V in and out model. Can’t be changed. Cheap enough for a punt on this problem; if no go, I can use it for something else. It’s not worth buying a 1ph 230V in, 3ph 230V out model for this one car - it would have to be specced a lot higher than the 3.5kW, given the lift application with its nearly locked-rotor starts.
The rotary is a commercially-made one for which I don’t have the wiring diagram. All the capacitors are in spec and there is a beefy 240V-415V transformer at the front end. The idler motor is a huge cast iron 7.5kW running in 415V delta (for star-delta starting in other applications).
I think there might be two main problems:
1. The rotary output is not perfect 3ph - unbalanced and perhaps not 120deg apart?
My hope is, the VFD will iron out all this and produce a ‘better’ output. I assume if the phases are unbalanced, this has an effect on the rotating mag field, and torque.
2. The lift motor is very small for the quoted power - no cooling fan or fins, only 0.65 pf, 30% duty cycle.
The VFD may help with that awful power factor. As you point out, the converter should easily do the job, but perhaps the reactive current is loading it down too much.
Edit: one last point I should make, is that good VFD and phase converter makers often ask on their websites that the customer ring them before ordering, if the unit is to be powering a car lift. So it seems to be a special case, perhaps because of the hard starts.
Motor plate, for interest:
Changing from a rotary converter to a VFD will not reduce the circulating reactive current due to the low PF.
1. First, clean and lubricate the screw(s) and nut(s). Lower the friction coefficient with a better lubricant.
2. Maybe if you place a delta of capacitors across the 3PH motor, you can bring the PF closer to 0.95. Do not overcompensate the inductance of the motor.
1. Done - it has automatic screw lubricators which have been cleaned out and topped up.
2. Yes, certainly something to try. I assume 3 equal values of capacitance - start at 5uF?
As I understand it, the motor is custom-designed to be used for minutes in the hour (pf not a priority), but must be able to dead-lift a 3.2-tonne car. The huge current draw from these factors is causing a power delivery problem, not so much a lack of power available.
I would like to experiment with the VFD, seeing as it’s coming anyway. For example, I notice from the motor plate that running at 60Hz boosts the pf to 0.82.
Measure the positive reactance of the motor at operating frequency. Then provide negative reactance to cancel most of that.
As a first attempt, looking at the motor plate (connected in star):
$$Z=\frac V I = \frac {400} {11} = 36.4\Omega$$
Find capacitor with Xc of that value at 50Hz:
$$ C = \frac 1 {2\pi f X_c} = 87\mu F$$
I don't know the details of the VFD that you're considering, but:
Reducing the output frequency would be (approximately) the torque equivalent of option #2 (gear down). Worth a shot, I think.
VFD manual should be linked in the first post. Yes, I thought lifting the car slower might reduce the loading of the system. Or, running at 60Hz might improve the power factor, according to the motor plate. All doable with a twiddle of a pot.
It seems very inefficient. Lifting a 2-tonne car at 30mm/sec only needs around 600W. All the rest of the draw, which is near enough 5kVA, seems to be friction and VARs.
The impedance of the motor is; Z = R + j X.
You should not try to neutralise the in-phase real power component.
Ok, so a cosphi of 0.65 gives an angle of 49.5 degrees:
$$Z=36.4\Omega <49.5° = 23.6 +j27.7\Omega$$
$$C=\frac 1 {2\pi f 27.7} = 115 \mu F$$
Simply put, the convertor is not optimized for the load. A wiring diagram for the convertor would be helpful. You will have the same voltage imbalance when powering the VFD with the convertor. Rotary convertors are optimized for a specific load. Capacitors are chosen to balance voltages and when the load changes the voltages will no longer be balanced. This is the case even if the the convertor is optimized for a heavy load and the load is lightened. The convertors I've been around were using wye wound idler motors. I'm wondering what the circulating currents are within your delta wound idler at various loads.
Could you post one or more pictures of the mechanical part of the lift?
Perhaps we can spot a source of high frictional loss.
The screw is on the right, and turns the other screw via two 90deg gearboxes and a driveshaft under the lift area. The lift nut is no. 19 and it lifts the squarish bracket (12), which in turn lifts the carriage with the arms that contact the car (not shown). Above all that is the autolubricator (8-11).
Number 21 is a safety nut, which normally carries no weight, but is there in case the main nut strips. If this happens, the linkage releases pawl 14 which engages with a stop on the column, preventing the car from being lifted.
I’ve renewed the phosphor bronze lift nuts and nylon carriage slides, and generally given everything a strip and clean/lube. I can turn the whole mechanism (unloaded) by hand via the screw pulley - it’s not easy but I wouldn’t say it’s binding. The screws do get hot in use.
It is an inefficient machine, but I guess this doesn’t matter since it’s only running for seconds in the hour. The manual specifies a 7.5kVA supply, presumably related to this and the huge inrush required when lifting a car already partway up.
Re: inrush - the single phase side of the supply needed a 32A C-curve MCB, rather than the typical B-curve. Under UK regs this is fine, provided the circuit loop impedance is low enough to ensure tripping within the required time (which it was).
The heating could be induced by the thread profiles of screws and nuts not perfectly matching, as when new.
If that is the case, extreme-pressure (EP) grease containing molybdenum disulfide may help.
Some load-induced misalignment could also be forcing the nuts not to work perfectly in line with the screws.
To test that, I would release all the screws anchoring brackets 12 to the lift just enough to slide or rotate a little respect to each other.
Thanks, I’ll get some EP grease. The only problem is, the lubricator is an oil reservoir, 11, and a tight-fitting felt wick, 9, which might just clean away the grease as it goes. I wonder if I could mix up some EP with the normal oil and try that?
The phosphor bronze lift nuts, acting on the hardened steel screw, should be a good friction pairing. They were made for me by a friend with a CNC lathe. There was a little bit of chatter in the threads. They may need to wear in. Trapezoidal TR40 x 5 (RH and LH) threads - not exactly off-the-shelf!
Will try loosening the screws, perhaps with a dead blow hammer to help them find their place?
On the electrical side, would @Baluncore (or other EE) mind confirming my capacitor calculation, so I can order the PFC caps?
Edit: Looking again at the calculation, I think the ##115\mu F## figure is the total capacitance needed, corresponding to three ##38\mu F## capacitors.
I’ve ordered three ##450V, 30\mu F## capacitors, having approached the calculation differently and got the same answer:
At ##400V, 11A, 50Hz, cos\phi=0.65, \phi=49.5°##:
##|S| = \sqrt 3 VI = 7.62 kVA##
##P = |S|cos\phi = 4.95 kW##
##Q = Ptan\phi = 5.80 kVAR##
The above with a ##cos\phi## of 0.95:
##|S| = 7.62kVA##
##P = 7.24 kW##
##Q = 2.38 kVAR##
##5.80 - 2.38 = 3.42 kVAR## to provide, or ##1.14 kVAR## per phase.
##C = \frac {Q} {V^2 2 \pi f} = 22.7\mu F##
Using the full ##5.80 kVAR## as the figure to provide, or ##1.93 kVAR## per phase:
##C = 38.0\mu F## as calculated above.
So, the common value of ##30\mu F## sits nicely in the middle.
Do not overcompensate the motor inductance with capacitors as, when you turn it off, the two will become a resonant self-excited generator, above the supply frequency. That can generate a voltage spike, that may damage the insulation of the motor, the switch, the 3PH converter, or VFD. You might consider some form of voltage protection for the motor during testing.
Make sure the capacitors are connected directly to the motor, so the circulating current does not pass through the switch wiring. During setup, you can increase the capacitance in 1, 2, 4, ... steps monitoring the total current, and noticing how it falls towards a minimum with increasing capacitance. Then back-off the capacitance, to compensate for only about 90% of the reactive current.
Measurement of motor inductance, involves making measurements while running the motor with a mechanically locked rotor, and with no load on the rotor.
https://en.wikipedia.org/wiki/Blocked_rotor_test
I once encountered an alternator that drove an overcompensated inductive lighting load, (since some inductive lights had been disconnected). When the alternator engine ran out of fuel, the alternator would cut, then a moment later, the engine would be driven by the alternator, restarting it on what little fuel had since flowed. That would cycle every few seconds, half a dozen times, before the lights finally went out. The lesson there was to compensate each load inductor, individually, where it was located.
As soon as power is cut, the motor stops dead from the friction. Does that allay any fears?
I’d guess that, at switch-off, we’ll be left with three LC tanks, complicated by the rotor nearby. Would they just ring down to nothing?
The motor being fairly modern and dual voltage/frequency, I suspect it’s inverter-duty, so should be better able to withstand voltage spikes and bearing damage.
That’s not especially practical for me, unfortunately, because I’d have to buy a whole box of motor caps. Are the calculations above not reliable in practice?
Is there an elephant in the room?
Is there a mention of the motor being in star or delta connection?
Maybe the motor is stuck in star, when it should be in delta.
Is there an internal centrifugal star-delta starter switch?
I’ve had the motor apart for testing the windings and changing the bearings:
It’s dual voltage, ie 230V delta or 400V star. Latter configuration currently. No internal switch.
Moly oil is also available. I'm not sure if the moly will fit through the felt pads. It might depend on the particle size.
BoB
An interesting short article on self-excitation in pf-corrected induction motors:
https://nepsi.com/resource/Self-Excitation Concerns.pdf
The key point is, if the capacitive reactance is greater than the motor magnetising reactance, as when the cap is deliberately under-sized, the resonant frequency of the pairing will be above line frequency. As the motor spins down, the dropping self-excitation frequency will therefore never hit resonance and not lead to voltage spikes.
As I suspected, this self-excitation effect does depend on the motor coasting to a halt, which doesn’t happen with my machine.
Edit: I think I made a mistake with the second part of the capacitor calculation, estimating the power triangle with a ##cos\phi## of 0.95. I kept the apparent power |S| the same, but it should drop under correction, along with the rms current. So, keeping real power the same:
With a ##cos\phi## of 0.95, and real power 4.95 kW:
##|S| = 5.21 kVA##
##P = 4.95 kW##
##Q = 1.63 kVAR##
##5.80 - 1.63 = 4.17 kVAR## to provide, or ##1.39 kVAR## per phase.
##C = 27.7\mu F##
Although if no-one’s checking my calculations, I might be flogging a dead horse. Three ##20\mu F## motor caps ordered, anyway.
You understand the compensation requirements.
I have not checked your calculations because your result is in the ballpark I expect. Whatever the computation, you will need to verify that the motor is not overcompensated.
I would use three each of; 5uF, 10uF, and 20uF, then experimentally approach the PF compensation by gradually increasing the capacitance in binary steps, while monitoring the total current.
Ok, well I have 30 uF and 20 uF coming, so that will give me the range 12-50 uF.
Checking for motor voltage spikes, I assume my Fluke 87V on peak detect should spot them?
Results:
Capacitance (uF):Current U:Current V:Current W:
013.413.18.3
1212.812.68.0
209.410.07.2
359.310.57.0
It looks like a low point around the 20 uF mark. At this level, subjectively, the motor sounds happier and gets less hot. Phase balance looks better, too.
Increasing to 35 uF doesn’t help much, and I think the current results at this level are lower than expected as the motor was warming up by this stage. It doesn’t have good cooling.
My guess is, 12 and 35 uF are leaning towards under- and over-compensation respectively, with 20 uF being a good mid-point, erring on the side of under-compensation as advised.
The Fluke didn’t pick up voltage spikes much above the expected peak of 600-620V (some line voltages are above the standard 400-415V).
P.S. I did wonder if it would be worth changing one or more of the correction caps to improve phase balance, i.e have an uneven delta?
Without a wider range of experimental capacitors, I would use 20uF in that application.
It is a case of balancing the inductive reactance against the capacitive reactance. The asymmetry of the converter voltage is not part of the neutralisation challenge, it just confuses it.
You are measuring line current only, which gives you a clue, but is not ideal. For a delta, you should be measuring phase current, which should be in phase with the differential voltage across that phase. That requires some way to compare voltage and current phase angles of only one winding. You would need to split the line entering the motor into two, to monitor the current through only one of the phase winding on the motor, while you compare that with the differential voltage of the lines that feed that phase.
It would be good if you had access to a clean 3PH supply, with balanced voltages, to set up the neutralisation. We do not know how much of the compensation is for the motor inductance, and how much is for the converter reactance.
  • · Replies 36 ·
14K
