Voltage across Capacitors in Parallel
The problem involves two capacitors, one charged and one uncharged, connected in parallel. The original poster seeks to determine the potential difference across both capacitors after they are connected.
  • Participants discuss finding the charge on the first capacitor and how it relates to the voltage across both capacitors. Questions arise about the conditions under which charge stops flowing and the implications of charge conservation.
Participants are actively engaging with the problem, exploring the relationship between charge and voltage in capacitors. Some guidance has been provided regarding the conditions for charge flow and the need for voltages to equalize, but no consensus on the final answer has been reached.
There is a focus on understanding the behavior of capacitors in parallel and the implications of charge conservation, with some participants questioning the assumptions made about the initial conditions of the capacitors.
rocketgirl93
A 10μF capacitor is charged to 5V and then isolated. It is then connected across a second uncharged capacitor of capacitance 15μF. The potential difference, in V, across both capacitors is A) 0.2 B) 0.5 C) 2 D) 3
C= Q/V Ct=C1+C2
Finding the charge of the first capacitor and trying to use this to find charge of the other to find voltage. Find the energy stored in the first capacitor and assuming this is the charge available to the second capacitor. Various other shifting about and substituting of equations. Nothing worked!
C= Q/V Ct=C1+C2
What shall remain constant when you connect both the capacitors? :wink:
The charge..? But you don't have the charge for the second capacitor, how do you find it?
Good!
Initially, the second capacitor doesn't have charge. Only first capacitor posses charge.
When you connect both, the charges will flow and come to a steady state. Till how long the charge should flow? What should be the condition so that charge should stop flowing between the capacitors?
The charge will flow until the other capacitor is charged up?
Yep.
So how much charge is there to begin with?
In the end the voltage across the 1st capacitor will have to be the same as the voltage across the 2nd capacitor.
So if we call this as yet unknown voltage V, can you give the formula of how much charge is on each capacitor?
Aaaaaah I think I just got it,
If the overall charge is the same, and the voltages across the two capacitors have to be the same, Qtotal = C1V + C2V = V(C1 +C2) so the answer is 2?
Yes. :approve:
Yay! Thank you so much for your help!
