Voltage of an infinite cylinder with nontrivial reference point
The discussion focuses on calculating the electric potential V(r) due to an infinitely long cylinder with uniform charge density ρ and radius R, using V(r = 2R) = 0 as the reference point. The electric field equations are established as E at r < R = (ρr)/(2ε₀) and E at r > R = (ρR²)/(2ε₀r). The integration process for both regions is detailed, resulting in V(r < R) = (ρ/4ε₀)(4R² - r²) and V(r > R) = (ρR²)/(2ε₀)ln(2R/r). The calculations are confirmed to be correct based on the provided electric field equations.
  • Understanding of electric fields and potentials in electrostatics
  • Familiarity with integration techniques in calculus
  • Knowledge of uniform charge density concepts
  • Proficiency in using ε₀ (permittivity of free space) in equations
  • Study the derivation of electric fields from charge distributions using Gauss's Law
  • Explore advanced integration techniques for electric potential calculations
  • Learn about the implications of different reference points in potential calculations
  • Investigate the behavior of electric fields and potentials in cylindrical coordinates
Students studying electromagnetism, physicists working with electrostatic problems, and educators teaching concepts of electric fields and potentials.
programmer1813
Find V(r), the electric potential due to an infinitely long cylinder with uniform charge density ρ and radius R.
Use V(r = 2R) = 0 as your reference point.
E at r < R = ##\frac{(ρr)}{2ε_{0}}##
E at r > R = ##\frac{(ρR^{2})}{(2ε_{0}r)}##
This is basically simple. Just integrate the electric fields to get voltage. The only problem is figuring out the limits of integration. I BELIEVE that if you have a nontrivial reference point outside of a cylinder, you will need to integrate from r to 2R for both inside and outside. So I did this:
$$V(r < R) = \int_r^R \frac{\rho r}{2ε_{0}}dr + \int_R^{2R} \frac{\rho r}{2\epsilon_{0}}dr = \frac{\rho}{4\epsilon_{0}}(4R^{2} - r^{2})$$
$$V(r > R) = \int_r^{2R} \frac{\rho R^{2}}{2\epsilon_{0}r}dr = \frac{\rho R^{2}}{2\epsilon_{0}}ln(\frac{2R}{r})$$
Does this look right?
Assuming your field calculations are correct, these look right.
I'm not following the logic behind your equations.
For r > R, the field is ##E = \frac{\rho r}{2\pi\epsilon_0 R^2}##, yes?
So for r > R, isn't the potential ##\int_{s=r}^{2R}\frac{\rho s}{2\pi\epsilon_0 R^2}.ds##?
