Volume Expansion Thermodynamics Question
The discussion revolves around calculating the volume expansion of carbon tetrachloride in a steel container due to a temperature increase from 10.0°C to 27.5°C. The average coefficient of volume expansion for carbon tetrachloride is given as 5.81 x 10^(-4) (°C)^-1. An initial attempt at the solution yielded an incorrect spillover volume of 0.438 gallons. Another participant suggests that the correct calculation results in a spillover of 0.483 gallons and prompts a review of the volume expansion equation used. Accurate calculations are crucial for determining the correct amount of liquid that will overflow.
AngelMizukage
The average coefficient of volume expansion for carbon tetrachloride is 5.81 multiplied by 10^(-4) (°C)-1. If a 47.5 gal steel container is filled completely with carbon tetrachloride when the temperature is 10.0°C, how much will spill over when the temperature rises to 27.5°C?
Use the equation of volume expansion
The answer I got was 0.438 gal but I know that this is wrong.
Check your math. I get .483 gal. What is the equation for volume expansion that you are using?
AM
