Archived Volume Expansivity of Ideal Gas
To calculate the volume expansivity, β, for one mole of ideal gas at constant pressure and room temperature, the formula β = 1/V(dV/dT) is used. The user initially struggles with the concept, questioning whether dV/dT would be zero under constant temperature and pressure conditions. However, it is clarified that dV/dT equals R/P when pressure is constant. Ultimately, the calculation leads to the conclusion that β equals 1/T. This demonstrates the relationship between volume expansivity and temperature for an ideal gas.
Seph79
Calculate the volume expansivity, β, for one mole of ideal gas at constant pressure and at room temperature.
β=1/V(dV/dT)
Bit stumped on this one, I'm guessing they want it in terms of P as P is not specified.
I used equation of state with n=1 giving PV=RT
> V=RT/P
> β=P/RT(dV/dT)
As the temperature and pressure are constant would dV/dt be zero?
Its from here I am stuck :confused: , any help welcome
Thanks
If V=RT/P, then (dV/dt) = R/P for P = const. Therefore
\beta = \frac{1}{V} \left( \frac{d V}{d T} \right) = \frac{P}{RT} \frac{R}{P} = \frac{1}{T}
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
