What Is the Volume Flux for a Hydraulic Jump?
Particle Head
Problem is given in this image,
https://gyazo.com/454370ff9549dcd7c53604ebfe5df105
Continuity or conservation of mass equation:
\frac{\partial u}{\partial x} + \frac{\partial w}{\partial z} = 0
Where u is the horizontal velocity and w is the vertical velocity
Firstly I integrated the conservation of mass equation with respect to x between the two points:
\int_ {x_1} ^ {x_2} \frac{\partial u}{\partial x} \mathrm{d}x + \int_ {x_1} ^ {x_2} \frac{\partial w}{\partial z} \mathrm{d}x = 0<br />
Which after evaluating I get,
u(x_2) - u(x_1) + x_2 \frac{\partial w}{\partial z} - x_1 \frac{\partial w}{\partial z} = 0
Firstly here I am not 100% sure I can assume w is just a function of z only, but I have yet to see it as a function of anything else other than t in 2D flow?
I then integrated the mass equation vertically first from z = 0 to z = h_1 and then from z=0 to z= h_2
\int_{0}^{h_1} \frac{\partial u}{\partial x} dz + \int_{0}^{h_1} \frac{\partial w}{\partial z} dz = 0
which yields,
h_1 \frac{\partial u}{\partial x} - w(0) = 0
Since w(h_1) = 0
Similarly for z=0 to z= h_2 I get,
h_2 \frac{\partial u}{\partial x} - w(0) = 0
This is where I am kind of stuck, from these two equations it appears h_1 = h_2 which doesn't make sense since this is a hydraulic jump and the nature of such is to increase the surface of the liquid.
Any hints where I may be going wrong here or missing something is appreciated.
Thanks.
First integrate with respect to z, using the Leibnitz rule for differentiation under the integral sign on the u term.
I try to integrate with respect to z first, I haven't used the Leibniz rule before but from what I can gather I can treat my bounds as constant thus I get this for the u term.
\int_{0}^{h_1} \frac {\partial u}{\partial x} dz = \frac {\partial}{\partial x} \int_{0}^{h_1} u dz
After evaluating this I get,
h_1 \frac {\partial u}{\partial x}
I'm not sure if I did this correct but following this doesn't seem to get me much further?
I suspect my math is off I haven't done any multi variable calc for a while.
$$\frac{\partial [\int_0^{h(x)}udz]}{\partial x}=\int_0^{h(x)}{\frac{\partial u}{\partial x}dz}+u(x,h)\frac{dh}{dx}$$
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
