Characterizing Volume in Equilibrium Thermodynamics
The discussion focuses on the relationship between the Helmholtz potential and volume in equilibrium thermodynamics, specifically referencing Callen's equation. It highlights that while the canonical partition function Z is not an integral in phase space, the dependence on extensive parameters like volume (V) and particle number (N) arises from the constraints of the canonical ensemble. The systems are assumed to exchange heat at constant temperature without mechanical interactions, leading to the constancy of these parameters. Questions are raised about the relevance of taking derivatives of the Helmholtz potential with respect to volume to determine pressure, emphasizing the importance of equilibrium thermodynamics in this context. The discussion underscores the significance of understanding these relationships within the framework of thermodynamics.
pt176900
from callen, equation 16.10 reads Z = sum(e^-BE)
the text later says that F = -kT ln Z, and states that it gives the helmholtz potential as a function of B, V, N
where B = 1/kT
my question is, what part of this relationship characterizes the volume?
Since the canonical Zustandsumme "Z" is not an integral in the phase space,for statistical systems in the quantum canonical ensemble it's not that obvious why the dependence on the extensive mechanical paramters like V & N needs to appear.
It comes up from the contraints we imposed upon the systems from the ensemble.Specifically,the systems exchange heat thus keeping the temperature constant,and that's it.They do not suffer other types of interactions,viz.NO MECHANICAL INTERACTIONS,therefore,in it's macroscopical description the extensive mechanical parameters are assumed constant and given.That's how u explain the dependence of 1/T,V,N,... for the Massieu function Phi or for Helmholtz potential F...
Daniel.
ok, so if it's a constant, then why would you take the derivative of the helmhotlz potential with respect to volume to determine the pressure of the system?
That's a question not in the realm of stat.mechanics,but in the one of EQUILIBRIUM THERMODYNAMICS.Ask yourself what is the point of taking the derivatives (all of them partial due to multiple variable dependence) in EQUILIBRIUM thermodynamics...
HINT:the key word is thermoDYNAMICS...
Daniel.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
