betz
- 1
- 0
I want to determine the volume of air in a scuba tank. Can someone tell me the formula if I know how much water the tank holds?
The volume of a scuba tank with a hemispherical end can be calculated using the formula V = (2/3)πr³ + πr²h, where r is the radius and h is the height of the cylindrical portion. The ideal gas law, V = nRT/P, is essential for determining the volume of air at different pressures, with R being the ideal gas constant. Common scuba tanks, such as the aluminum-80 (AL80), hold 80 cubic feet of air at a working pressure of 3000 psi. Understanding these calculations is crucial for divers to ensure proper air supply during dives.
PREREQUISITESScuba divers, diving instructors, and anyone involved in the design or maintenance of scuba equipment will benefit from this discussion, as it provides essential calculations and insights into scuba tank volumes and gas laws.
Hopefully, your scuba tank doesn't contain waterbetz said:I want to determine the volume of air in a scuba tank. Can someone tell me the formula if I know how much water the tank holds?
It's probably worth pointing out that the ideal gas law is actually V = nRT/P, where n is the number of moles of gas present - probably the most important number, if you're interested in how much air is actually available to breathe.red_fox77 said:But better yet, to calculate the volume of air in the tank, use the ideal gas law (close enough for pure O2) V=RT/P. What this tells you is your pressure will depend on the temperature (in K) you are swimming at. R is the ideal gas constant, and the value depends on which units you want to use for V. Search google for 'R ideal gas' for some charts on which value to use.
Will.
Nenad said:A scuba tank has only one hemispherical side, the other side is flat, it even curves inward a bit. The real formula is:
V = \frac{2}{3}\pi r^3 + \pi r^2h
