Volume of cathedral dome (Using volumes of revolution, disk method)
insane0hflex
A cathedral dome is designed with three semi circular supports of radius r so that each horiontal cross section is a regular hexagon. Show that the volume of the dome is r^3 * sqrt(3)
an accompanying figure - http://imgur.com/3fSqh
Vdisk=∫pi*(f(x))^2 dx
That dome is not a solid of revolution since the cross sections are not circles. What you need to do is figure out the area of the hexagonal cross section at height h and do the volume by integrating cross section areas for h from 0 to r.
Okay, that helps a little bit. So I would derive an expression for the area of the base, then take the integral from 0 to h? (since h = r correct)?
No, that isn't correct. You don't start with the area of the base. You want the area of the upper hexagon in the picture, which will depend on h. h is the distance from the base to the plane of that hexagon, in other words the variable distance between the two red dots.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
