Volume of gas in a cylindrical vessel on which a piston has been placed
The discussion focuses on calculating the volume of gas in a cylindrical vessel with a piston under varying temperatures and pressures. The problem states that a mass is needed to hold the piston in place when the gas is heated from 20°C to 80°C, and participants clarify the importance of atmospheric pressure in the calculations. The ideal gas law (PV=nRT) is highlighted as the primary equation to use, with emphasis on determining the pressures at both temperatures. Confusion arises regarding the number of moles of gas and the need for precise problem formulation. Ultimately, the relationship between pressure, volume, and temperature is reiterated as essential for solving the volume of the gas.
merbear
[SOLVED] volume of gas in a cylindrical vessel on which a piston has been placed
A cylindrical vessel with a tight but movable piston is placed in a vertical position so that the piston, whose area is 60 cm2, is subject to atmospheric pressure. When the gas in the vessel is heated from 20oC to 80oC, a 0.6 kg mass must be placed on top of the piston to hold it at the position it occupied at lower temperature.
What is the volume of 0.3 mol of the gas?
Pv=nRT
Since we were given the moles of gas (.3 mol) and we know R since it's a constant, I assumed that the pv=nRT would be the correct equation. I found the pressure of the cylinder with the weight on to be the pressure by the weight: P=F/A= [(.6 kg * 9.8 m/s^2)]\.6m^2. The temperature I put was 353K - that of the second cylinder.
I got a volume of 53.9 m^2 but I know that the volume must be much greater, given the size of the cylinder in the problem. I don't know how else to go about the problem so I would appreciate any help.
Thank-you!
Under what T and P? Without that, the question is meaningless. Also, it is not mentioned in the problem that the amount of gas is 0.3 moles. The length of the cylinder is also not given.
What are known are these:
P1/T1 = P2/T2, since the volume remains the same.
P2 - p1 = W/A, where W is the weight of the mass, A = area of piston.
So, P1 and P2 both may be found.
Still a bit confused about the cylinder question
I don't understand what you mean when you say, 'under what temperature and pressure'. The question stated that you had one cylinder at 20 degrees and the other one with the weight on it at 80 degrees. It also stated that the piston is subjected to atmospheric pressure. Does the atmospheric pressure not need to be accounted for?
I see how you were saying to solve p1 and p2, but I don't see where to go from there. Would you use the pressure difference to solve for the volume of gas using pv=nRT?
The question should have been formulated more precisely. In the main problem, it is not mentioned that there were 3 moles of gas. At the very last, it is asked, "What is the volume of 0.3 mol of the gas?", which does not imply that there were 3 moles inside. Anyway, let it go.
The P_atm is acting on both cases and is included in P1 and P2. In fact, if the piston is very light, P1 = P_atm. But we can do without knowing the value of P_atm.
P1V = nRT1 and P2V = nRT2 =>
(P2-P1)V= nR(T2-T1).
You can get V now.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
