Water valve for a cylindrical container
A mechanism is needed for quickly releasing water from a cylindrical pole via a switch, with concerns about the watertightness of the design. Suggestions include using a ball valve with automatic control for rapid operation, as well as ensuring proper design of the valve seating surface and guidance for the bar. The design should consider various mechanical aspects such as seating loads and material compatibility to avoid leakage. Alternative designs include a horizontal hole with a vertically oriented bar or a cylindrical bar with a hole that rotates to cover or uncover the opening. Overall, the discussion emphasizes the importance of evaluating design benefits and drawbacks to improve the initial concept.
Quincy
I need help designing a mechanism for quickly releasing water through a tiny hole on one end of a thin cylindrical pole by a switch/button/etc on the other end. I have thought of one way to do this and drew an illustration, which is in the attachment. But I'm not sure if when the bar is covering the hole, whether it will be watertight or not. If anyone knows of a way I can improve this idea or if anyone has other ideas, let me know.
Get a ball valve with an automatic control on it. I just assembled one today that can slam the valve open and close in .25 seconds.
Hi Quincy,
I think all you're trying to do is make a valve that is integral with a water reservoir. Your idea will work in theory, but it requires proper design of the valve seating surface and guidance of the bar. Like any valve, there are many aspects you need to look at such as seating loads, material compatibility, stresses, actuation forces, etc... I would consider your idea and any idea like it to be the starting point and go from there. So the first thing you should do in designing ANY mechanical device is to consider various ways it can be done and try to understand what the benefits and drawbacks are that are inherent to the various designs. In this case, the benefit might be simplicity and the potential to make the seating surface pressure energized. Drawbacks might include the fact the bar will be drawn across the seating surface which has the potential of scoring the surface and allowing leakage. I'll toss out a few other ideas...
You might have a design with the hole being horizontal instead of vertical and have the valve stem (bar) oriented directly above the hole so pushing down covers the hole and lifting up exposes it (or visa versa if you wanted). This design can be pressure energized or pressure balanced. The bar would of course be guided. The bar could have an actuator (automatic or manual) that pushed directly down on it or the actuator could be a screw type mechanism such as most common globe valves have.
Another option would be to make the bar cylindrical with a hole in it like a ball valve and guide the end so that rotating the cylindrical bar covers or uncovers the hole. Like ball valves, and the valve you suggested, the seat can be pressure energized but consideration must be given to scoring the seat.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
