Phase Shifting Wave Functions: A How-To Guide
SpaceTrekkie
Show that a wave function is phase-shifted by (pi)/2 when multiplied by
i and by (pi) when multiplied by −1.
The wave function form I am using is function = A(cos(kx-wt)+isin(kx-wt))
But it was not specified which kind I can use
I am not sure even where to begin...
I think this is not a physics question, just a mathematics one :smile:
Phase-shifting by \phi means replacing \psi \to e^{i \phi} \psi (\phi is called the phase, because the phase factor exp(i phi) only changes the argument and not the modulus of psi, so physical quantities which generally depend on |\psi| are not affected by such a change).
So basically what they want you to show, as far as I can tell, is that if you set phi = pi / 2 then that's the same as changing psi for i psi - which is mathematics, not physics; and very easy too.
Thanks, I actually manged to figure it out after I posted, thank goodness. Yeah, I guess that was actually math, but it was for my wave optics class which is physics 306 so I put it here :-)
