Wavefunction with specific values
The discussion focuses on calculating the probability of locating a quanton based on its wavefunction values at two positions, xA and xB. The probability density is derived from the wavefunction, with Pr(xA) calculated as 0.09 and Pr(xB) as 0.0288. The ratio indicates that the quanton is approximately 3.125 times more likely to be found near xA than in a larger range around xB. Participants confirm the approach used to derive these probabilities is correct. The explanation of probability density in relation to the wavefunction is also clarified.
Gringema
Near a certain position xA, a quanton's wavefunction ψ(xA)=-0.3 in some units. Near a certain position xB, a quanton's wavefunction ψ(xB[\SUB])=0.12 in the same units. If we do an experiment to locate the quanton, how many times more likely is i that the result is in a small range near xA than in a range twice as large near xB? Please explain.
ψ(x)=ψ/sqrt(Δx)
|ψ|2=Pr(x)
I used the definitions of wavefunction and amplitude to get Pr(x)=|ψ(x)|2Δx.
So Pr(xA)=(-0.3)2=0.09
And Pr(xB)=2(0.12)2=0.0288
Therefore Pr(xA)=3.125Pr(xB)
Is this the right way to think about this? And how would I "explain"?
ψ(x)=ψ/sqrt(Δx)
|ψ|2=Pr(x)
|ψ(x)|^2 is the probability density of finding the particle around some specified x. So the probability that a particle is in a narrow range of width Δx around x is P = |ψ(x)|^2 Δx.
So P(xA) = Δx(-0.3)2=0.09 Δx and Pr(xB)=2Δx(0.12)2=0.0288 Δx, but you got the ratio correctly.
ehild
