Wavelength - Yellow line in the spectrum of a sodium lamp
In summary, the outermost electron in a sodium atom can exist in three energy states, with the energy being -0.82 aJ, -0.48 aJ, and -0.31 aJ. Using the frequency and wavelength equations, it was determined that the yellow light observed in the spectrum of a sodium lamp has a wavelength of 585 nm.
mstud
69
The outermost electron in a sodium atom can be in these energy states: (1)-0.82 aJ, (2) -0,48 aJ, (3) -0.31 aJ [itex]1 aJ= 10^{-18} J[/itex].
When we study the spectrum of a sodium lamp, we see a yellow line.
Use the above given energy states to determine the wavelength of this yellow light. Visual light: 400 nm to 750 nm
[itex]E_{photon}=hf [/itex] where h is Planck's constant: [itex]h=6.63 \cdot 10^{-34}[/itex]
[itex]c=f\lambda[/itex]
I can only find one ultraviolet and one infrared wavelength from the given energy states.
frequency: [itex]f=\frac {E_f}{h} = \frac {-.31 \cdot 10^{-18}J -(-.82 \cdot 10^{-18} J))}{6.63 \cdot 10^{-34} Js} \approx 7.69 \cdot 10^{14}[/itex]
Wavelength: [itex]\lambda = \frac{c}{f}=\frac {3 \cdot 10^8 m/s}{7.69 \cdot 10^{14}}=3.90 \cdot 10^{-7}= 390 nm[/itex]
This is in the UV-part of the spectrum. Similar problem arises with the other energy transiteration.
However the answer key says 585 nm.
Please help!
Please help!
You must have done something wrong. One of the differences does give 585 nm. Check your work. Also, you can use E = hc/λ to relate directly the energy to the wavelength.
That's true, yesterday I only thought of two possible movements between the energy states, but there were three. And the third one was the one I should use. Thank you for taking time to help...
Related to Wavelength - Yellow line in the spectrum of a sodium lamp
What is a "wavelength"?
A wavelength is a measure of the distance between two consecutive peaks or troughs of a wave. It is commonly used to describe electromagnetic radiation, such as light.
What is the significance of the yellow line in the spectrum of a sodium lamp?
The yellow line in the spectrum of a sodium lamp is a very distinct and prominent line that is produced when the element sodium is excited by electricity. This line has a wavelength of approximately 589 nanometers and is used in various applications, such as streetlights and some types of lighting for photography.
How is the wavelength of the yellow line in a sodium lamp measured?
The wavelength of the yellow line in a sodium lamp can be measured using a device called a spectrometer. This instrument separates light into its individual wavelengths and allows for precise measurement of the yellow line.
Why is the yellow line in the spectrum of a sodium lamp important in astronomy?
The yellow line in the spectrum of a sodium lamp is important in astronomy because it is used as a calibration standard for measuring the wavelengths of other celestial objects. This is because the yellow line is a known and consistent wavelength, making it a reliable reference point for astronomers.
Can the wavelength of the yellow line in a sodium lamp be altered?
No, the wavelength of the yellow line in a sodium lamp is a characteristic of the element sodium and cannot be altered. However, the intensity of the line can be changed by adjusting the amount of sodium present in the lamp or the amount of electricity used to excite it.
  • Other Physics Topics
