How Does Hooke's Law Affect Wave Propagation in Stretched Rubber Bands?
  • Thread starter Thread starter DivGradCurl
    Law
Hooke's Law applies to rubber bands used in baseballs and golf balls, affecting wave propagation. The speed of transverse waves in a stretched rubber band is derived as v = √(kΔl(l + Δl)/m), where k is the spring constant, Δl is the stretch, and m is the mass. For small stretches (Δl << l), the wave speed simplifies to v = √(kl/m), leading to a travel time t proportional to √(Δl). Conversely, for large stretches (Δl >> l), the speed becomes v = √(k(Δl)²/m), with the travel time t being constant. The discussion confirms the correct application of these principles in both scenarios.
DivGradCurl
Hi,
Could you please give a hand with this question from the book "Fundamentals of Physics/Halliday, Resnick, Walker" - 6th ed, page 395, #22P. Here it goes:
The type of rubber band used inside some baseballs and golf balls obeys Hooke's Law over a wide range of elongation of the band. A segment of this material has an ustretched length l and mass m. When a force F is applied, the band stretches an additional length &Delta;l.
(a) What is the speed (in terms of m, &Delta;l, and spring constant k) of transverse waves on this stretched rubber band?
(b) Using your answer to (a), show that the time required for a transverse pulse to travel the length of the rubber band is proportional to 1/&radic;(&Delta;l) if &Delta;l << l and constant if &Delta;l >> l
Comments:
(a) v = &radic;([tau]/[mu]), where [tau] = F = k&Delta;l and [mu] = m/(l+&Delta;l). This gives: v = &radic;{[k&Delta;l(l+&Delta;l)]/m} --- This should be right.
(b) I'm not sure what happens in either case... my guess is that when:
&Delta;l << l, we have: v = &radic;[(kl)/m].
v = dl/dt Then: [&int;(0,&Delta;l)] dt = [&int;(0,&Delta;l)] (1/v) dl
This gives: t = [2&radic;(&Delta;l)]/&radic;(k;m)
That doesn't seem to fit, but could be close.
&Delta;l >> l, we have: v = &radic;{[k(&Delta;l)^2]/m}.
This gives: t = [1/&radic;(k;m)]
That doesn't seem to fit, but could be close as well.
Thanks a lot!
Just a correction
Over comment for (b) [squ](k;m) = [squ](k/m)
Your approach to part (a) is correct. The speed of the transverse wave is indeed given by v = &radic;([k&Delta;l(l+&Delta;l)]/m).
For part (b), you are on the right track. The main concept to understand here is that the speed of the wave is directly proportional to the square root of the tension (k) and inversely proportional to the square root of the mass per unit length ([mu] = m/(l+&Delta;l)).
In the case where &Delta;l << l, we can assume that l+&Delta;l is approximately equal to l. Therefore, the mass per unit length becomes [mu] = m/l. Plugging this into the equation for v, we get: v = &radic;([k&Delta;l(l+&Delta;l)]/m) = &radic;([k&Delta;l(l)]/m) = &radic;(kl/m). This is the same as your answer for the speed in this case.
Now, to find the time for the pulse to travel the length of the rubber band, we use the equation v = dl/dt. Rearranging for dt, we get: dt = dl/v. Integrating this from 0 to &Delta;l, we get: t = [&int;(0,&Delta;l)] dl/v = [&int;(0,&Delta;l)] dl/&radic;(kl/m). Simplifying this, we get: t = [2&radic;(&Delta;l)]/&radic;(k;m). This matches your answer and shows that the time is proportional to the square root of &Delta;l in this case.
In the case where &Delta;l >> l, we can assume that &Delta;l is much larger than l. Therefore, the mass per unit length becomes [mu] = m/&Delta;l. Plugging this into the equation for v, we get: v = &radic;([k&Delta;l(l+&Delta;l)]/m) = &radic;([k&Delta;l(&Delta;l)]/m) = &radic;[k(&Delta;l)^2/m]. This matches your answer for the speed in this case.
Following the same steps as before, we get: t = [&int;(0,&Delta;l)] dl/v = [&int;(0,&Delta;l)] dl/&rad
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
