Weigh heavier at the equator or at the north pole?
An object appears to weigh heavier at the poles than at the equator due to the effects of gravity and centripetal force. Actual weight is determined by gravitational force, while apparent weight is influenced by the normal force measured by scales. The Earth's radius is smaller at the poles, resulting in a stronger gravitational pull compared to the equator. Additionally, the centripetal force at the equator, due to Earth's rotation, reduces apparent weight. Therefore, while actual weight remains constant, apparent weight varies based on location.
hueyhuey
One quick question about forces i have. Would an appear appear to weigh heavier at the equator or at the north pole? I assume both places would have have the same weight. A little feedback would be appreciated
There is a distinction here to be made regard actual weight and apparent weight. Your actual weight is simply the force of gravity exerted on your mass. Your apparent weight is the magnitude of the normal reaction force exerted by the ground on you; this is the weight that a set of bathroom scales measures. To answer your question you need to consider the following points;
  • What is the radius of the Earth at the poles compared to the radius at the equator?
  • I assume that you have studied basic mechanics and hence uniform circular motion. If this is the case consider your angular frequency as the Earth rotates when you are stood at the poles compared to when you are stood at the equator. How will the centripetal force differ in each situation?
  • Draw a free body diagram in each case to analyse the forces.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
