What are the rules for using the limit comparison theorem in power series?
The discussion focuses on the Limit Comparison Theorem in the context of power series, particularly regarding its application in calculus problems. Participants seek clarification on the theorem's rules and how to choose appropriate comparison series, such as the Riemann p-series. The theorem states that if the limit of the ratio of two series is a positive finite number, both series share the same convergence behavior. However, if the limit is zero or infinity, further analysis is required, as these cases do not provide conclusive results about convergence. The conversation also touches on specific problems from a practice exam, highlighting the need for deeper understanding of derivatives and series expansion.
Richter915
Hi, I'm preparing for my calculus II final and I had a question about Power Series. I'm posting the link for the answer solution to a practice exam (it's in pdf form) and I will ask questions based on that.
http://www.math.sunysb.edu/~daryl/prcsol3.pdf
On problem 12 it asks for the fifth derivative, I'm not sure why they did the last part. I can do the first three steps and solve for the power series of f(x) but I have no clue why they do that last part so if you can clear it up it would be appreciated.
On problem 7 part F...can you please explain the rules for limit comparison theorem. Also, when facing a problem like that, what series are good to use in comparison to the series given to you?
Thanks for any help, more questions will be asked in the future...heh.
On problem 12 it asks for the fifth derivative, I'm not sure why they did the last part. I can do the first three steps and solve for the power series of f(x) but I have no clue why they do that last part so if you can clear it up it would be appreciated..
They use the fact that if a function f can be written as a power serie \sum a_kx^k, then a_k = f^{(k)}(0)/k!. So they only look at the coefficient of x^5 and they're assured that it is f^{5}(0)/5!.
How it works: You chose a serie of positive n-th term b_n for which you know wheter it converges or not. Then you compute the limit
\lim_{n\rightarrow \infty}\frac{|a_n|}{b_n}
i) If the result is any number that is not 0 or infinity, the two series have the same convergence value. So if b_n diverges, a_n too and if b_n converges, a_n too.
ii) If the limit is 0, and if b_n converges, |a_n| converges.
iii) If the limit is \infty and if b_n diverges, then |a_n| diverges.
Otherwise, you cannot conclude.
Good series to use as b_n are the "Riemman p-series":
\sum \frac{1}{n^p}
it diverges for p \leq 1 and converges for p>1.
http://www.math.sunysb.edu/~leontak/prfinal.pdf
http://www.math.sunysb.edu/~leontak/solpf.pdf
Hi I was unsure of the explanation of the answer for question 13 part a. I understand everything up to where he finds the pattern shown by the recursive relation but after that, I'm not sure how he solves for y(x).
Also, can you please explain the solution to 14b. I don't understand the thing with the long division, everything before that I recognize..please help...thanks.
\sum \frac{1}{n^p}
so with points ii and iii...what if b_n was divergent and the lim was 0? What would that mean? And with iii, what if the lim goes to infinity and b_n converges? what happens then?
Thanks.
These cases are covered in "Otherwise, you cannot conclude."
That is to say, if we get that b_n was divergent and the lim was 0 or that the lim goes to infinity and b_n converges, the test doesn't tell us anything about the convergence of |a_n|, and we have to try comparing it with another b_n or try another test.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
