What are the Work and Energies of Mass A and B in a Pulled System?
The discussion centers on the work-energy theorem as applied to two objects of different masses, A and B, being pulled by the same net force over the same distance. The work done on object A is established as 500 J, leading to the conclusion that the work done on object B is also 500 J, due to the equal force and distance. The kinetic energy of object A can be derived directly from the work done, while the kinetic energy of object B is also equal to the work done on it, affirming the principle that the change in work equals the change in kinetic energy.
  • Understanding of the work-energy theorem
  • Basic knowledge of kinetic energy calculations
  • Familiarity with Newton's laws of motion
  • Ability to manipulate algebraic equations
  • Study the work-energy theorem in detail
  • Learn how to calculate kinetic energy using the formula KE = 1/2 mv^2
  • Explore examples of net force applications in physics
  • Investigate the implications of mass on acceleration and velocity
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in physical systems.
Eternal Sky
Problem: Two objects of different mass start from rest, are pulled by the same magnitude net force, and are moved through the same distance. The work done on object A is 500 J. After the force has pulled each object, object A moves twice as fast as object B. (a) How much work is done on object B? (b) What is the kinetic energy of object A after being pulled? (c) What is the kinetic energy of object B after being pulled?
[itex]W_n_e_t = \frac{1}{2}mv_2^2 - \frac{1}{2}mv_1^2[/itex]
I believe that the answer to part (a) is 500 J also, since both objects are pulled through the same distance by the same force. I attempted to solve part (b) by using the above equation, but since I don't know the mass or the velocity, it didn't work out.
If someone could help me, I would greatly appreciate it.
Hi Eternal Sky! :smile:
ah … the whole point of the work-energy theorem … ∆W = ∆KE … is that you don't need to know how to calculate KE …
(so you don't even need the whole of that equation of yours :wink:)
you just calculate ∆W, and ∆KE is automatically the same! :biggrin:
Ah, I see. Thanks a lot for your help!
  • · Replies 23 ·
  • · Replies 58 ·
