A What are typical initial conditions for the Schrödinger eq?
SeM
Hi, I am wondering if there exists some general initial conditions for solving the Schödinger eqn. for 1D free electrons ?
Thanks!
Typically, in solving Schrodinger's equation, you are either doing a time-dependent analysis, in which case the initial conditions are part of the problem statement, or you are doing a time-independent analysis, in which case, people are usually looking for energy eigenstates.
If you are doing a time-dependent analysis, the initial condition might be that the electron is a wave-packet of some sort localized at some particular position and momentum.
Likes Demystifier, vanhees71 and SeM
Hi, I am doing a time-independent analysis, and thought of using the zero-point energy for E, in the Schrödinger eqn, and then solve it with the two initial conditions:
1) assume that the wavefunction is 1 at position zero (x=0), as it would be normalized to.
2) its slope, Psi', is zero at the same point, x=0. Does this sound reasonable?
Thanks
Thanks
If you already know a complete set of energy eigenstates then you can find a solution having those properties. Those properties don't help you find the eigenstates, though.
Likes SeM and vanhees71
I know, there is another procedure to find the eigenstates. This is just to find the analytical solution to the ground state.
I'm not sure what you mean. The ground is the eigenstate with the lowest energy. So if you know the eigenstates, you already know the ground state.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
