Which bolt should be used for a beam support with different yield strengths?
  • Thread starter Thread starter engtobe
When selecting a bolt for a beam support, the yield strength of the bolt is crucial, as it should be designed per the bolt's yield strength rather than the material being bolted. The discussion highlights that different yield strengths of the plate and bolt can lead to varying bolt diameters, with the lower shear strength of the plate necessitating a larger bolt diameter. Ultimately, the appropriate bolt size should prioritize the bolt's yield strength to ensure structural integrity. Proper design considerations must account for stress-limiting factors in the joint geometry. The conclusion emphasizes the importance of adhering to these engineering principles for optimal performance.
engtobe
I have calculated two diameters of a bolt to be used in a beam support using a plate at each side supported in a cradle with a hinge pin.
i used shear strength and a constant load to find the diameters the reason i have two different diameters is because the plate and bolt have different yeild strengths
the plate has the lower shear strength and resulted in a bigger diameter of bolt.
what bolt should be used?
thanks for any answers
You design a bolted joint per the yield strength of the bolt, not the material it's bolting (unless the geometry has stress-limiting factors).
nice one mate
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
