What does a negative temperature coefficient of resistance mean?
A negative temperature coefficient of resistance indicates that as temperature increases, the resistance of the material decreases. This behavior is typical of semiconductors, where the number of charge carriers increases with temperature, enhancing conductivity. In contrast, metals generally exhibit a positive temperature coefficient, where resistance increases with temperature due to increased scattering of charge carriers. The distinction between these behaviors is crucial for understanding material properties in electronics. Overall, a negative temperature coefficient signifies improved conductivity with rising temperature.
xllx
If a material has a negative temperature coefficient or resistance, what does this mean?
Does it mean that as temperature increases, the resistance will increase instead of decrease.
Or something totally different?
Any help at all would be greatly appreciated! Many Thanks!
Other way round.
The conductivity increases with temperature, ie resistance decreases.
In general, electrical resistivity of metals increases with temperature (+ve), resistivity of semiconductors decreases with increasing temperature (-ve).
It means that the resistivity will decrease (or the conductivity will increase) with an increase in temperature. This is a common feature of semiconductors, because the number of charge carriers increases strongly with temperature. In metals, conversely, the number of charge carriers isn't strongly dependent with temperature. Instead, the dominating effect is increased carrier scattering with temperature. This results in a positive temperature coefficient of resistance: increased resistance due to a temperature increase.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
