DeltaXDeltaP Greater Than or Equal to h/4pi
  • Thread starter Thread starter C Rob
    Mean
The principle that deltaXdeltaP is greater than or equal to h/4pi indicates that the uncertainty in position and momentum cannot be simultaneously minimized to zero. This relationship implies that precise measurements of both quantities are impossible. The discussion highlights the mathematical foundation of this concept, linking it to the properties of the Fourier transform. This uncertainty principle is a fundamental aspect of quantum mechanics. Ultimately, it underscores the inherent limitations in measuring physical properties with absolute accuracy.
C Rob
deltaXdeltaP is greater than or equal to h/4pi.
It means that the product of the uncertainty in the measurable quantities position and momentum always exceeds that non-zero number.
Therefore, you cannot make fully exact measurements.
From a mathematical point of view, it is a property of the Fourier transform, if I'm not mistaken.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
