What Eigenvalues Lead to Square-Integrable Eigenfunctions?
The discussion revolves around an eigenvalue problem involving an integral equation and seeks to determine the eigenvalues that lead to square-integrable eigenfunctions. The context is rooted in functional analysis and differential equations.
  • Participants explore various methods to solve the differential equation derived from the eigenvalue problem, including separating variables and substituting different forms for the eigenfunction. Questions arise regarding the conditions under which the solutions remain square-integrable.
Multiple participants are actively engaging with the problem, offering different approaches and questioning the assumptions made about the solutions. Some guidance has been provided regarding the need for solutions to be finite at the lower endpoint of the integral, but no consensus has been reached on the eigenvalues that yield square-integrable functions.
There is an ongoing discussion about the implications of negative eigenvalues and the conditions for square integrability, with participants expressing uncertainty about the completeness of their solutions and the potential for other valid eigenvalues.
Felicity
solve the eigenvalue problem
(-∞)x dx' (ψ(x' ) x' )=λψ(x)
what values of the eigenvalue λ lead to square-integrable eigenfunctions?
(-∞)xdx' (ψ(x' ) x' )=λψ(x)
differentiate both sides to get
ψ(x)x=λ d/dx ψ(x)
ψ(x)x/λ= d/dx ψ(x)
2xe x^2 =d/dx e x^2
so ψ(x) = e x^2 and λ = 2
but this is not square integrable so either this is incorrect or there are other solutions I am not seeing
Can anyone help me find what I am missing?
Thank you
You want to solve the differential equation, ψ(x)x/λ= d/dx ψ(x) Separate the variables. You should get a solution with a lambda in it. Figure out what values of lambda make it square integrable.
Hello,
I think there are other solutions.
Take your equation,
[tex]x\psi\left(x\right) = \lambda\frac{d}{dx}\psi\left(x\right)[/tex]
and substitute [tex]\psi\left(x\right) = \exp\left(f\left(x\right)\right)[/tex] and see if you don't get an equation for [tex]f\left(x\right)[/tex] which has a solution that depends on [tex]\lambda[/tex].
Also, don't forget your solution has to be finite at the lower endpoint of the integral ([tex]-\infty[/tex]) in the original problem statement.
ok i separated variables, integrated and got
ψ(x)=e1/(2λ) x2
however I don't see how this can be square integrable since for any value of λ I can think of the integral of the square will equal infinity. I feel like I am missing something obvious here but I don't know what it is
ψ(x)=e1/(2λ) x2
Will it equal infinity even if lambda is negative?
of course! I am so embarrassed, thank you
  • · Replies 18 ·
