What Flexible Seal Can Withstand 500°C and Allow Linear Motion?
The discussion centers around the search for a flexible sealing element capable of withstanding high temperatures (500°C) while allowing linear motion of a moving object. Participants explore various sealing options and considerations related to material properties and application requirements.
  • One participant suggests a Teflon curtain as a potential sealing solution, although this is based on limited information.
  • Another participant highlights the complexities of elastomeric sealing at high temperatures, referencing the Dupont Chemical Resistance Guide and noting significant potential losses in mechanical properties.
  • Questions are raised about the thickness of the sealing barrier, the size of particulates to be excluded, and the speed of the moving object, indicating that these factors may influence the sealing solution.
  • A participant emphasizes the importance of finding a flexible sealing solution that allows motion, while also noting that the smallest particulate size is currently less critical than achieving effective sealing against oil particles.
  • Recommendations are made to consult with specific individuals who have expertise in sealing technology, suggesting that further specialized input may be beneficial.
There is no clear consensus on the best sealing solution, as participants propose different materials and approaches while also raising questions about specific application requirements. The discussion remains unresolved regarding the optimal sealing element.
Participants mention various factors that could affect sealing performance, such as temperature tolerance, flexibility requirements, and the nature of the media being sealed. The discussion reflects uncertainty regarding the best material choice and the implications of mechanical properties under high temperatures.
Individuals working on high-temperature applications requiring flexible sealing solutions, engineers involved in sealing technology, and those interested in material properties at elevated temperatures may find this discussion relevant.
yanikomer
I am working on a project where I need a high temperature sealing element. You can see the system in the attachment.
My moving object is moving linearly in a motion slot which is constructed on a sheet metal plate. But the surrounding temperature in this process is 500 C degree and there must be a flexible sealing element which does not let any particules or liquid material (oil etc.) to the behind of the sheet metal plate. As you see in the photo, I want the clearance between moving object and the sealing element as small as possible.
Does anyone know such a flexible sealing element that I can use in such a high temperature level and it also allows the motion of the moving object?
Thanks
yanikomer
I don't see any attachment, but my best guess based upon your typed post would be some sort of Teflon curtain. That's all that I can think of with the given information.
Elastomeric sealing at high temperatures vs an oil is a delicate subject. Check out the Dupont Chemical Resistance Guide and you can get started there. As you'll see, volume swell, compression set, and other mech. properties will be represented as % losses. And those representations are fairly large brackets, like 10-15%. So, depending on the tolerance of your application, this may be a pain in the arse to work around. And of course, all the reference materials you'll find online clause themselves with lines like "performance subject to verification" or similar.
I can offer some tips, fill out these fields:
the Flowed media is:
the ambient temperature:
leakage spec:
flexible -- how flexible is flexible?:
Mode of sealing - dynamic, static, etc etc..
Oh, wow... that is totally not what I was expecting. So your part travels along between the sealing surfaces like the slider on a zipper? It has to seal ahead and behind, and keep up with the motion in real-time.
Nathan is obviously very knowledgeable in this subject, so I defer to his expertise. I'm just going to ask a couple of questions in order to increase my own education, if you don't mind. One is how thick this barrier must be. By that I mean that if you are looking at it from the viewpoint shown in your picture, how "deep" into the page would it go? Also, what is the smallest particulate size of the solids that must be excluded? How fast does your slider have to move? Sorry if I'm being a pest, but you've got me curious.
Thank you Danger for your answer.
Actually the thickness of the seal element is about the heat transfer between the hot chamber and the beside of sealing element. This is also important but the first thing here is to find such a flexible sealing which allows the motion of the object there.
For example the width of the red moving object in the picture is about 10 mm and we can assume the witdh of the channel in the on the sheet metal as 20 mm.
Actually the sealing is used here just because not to let the oil particules to the behind of the sheet metal part. But after working on some kind of flexible sealing elements, i see that it is not so easy to achieve this kind of sealing. So that the smallest particule size is not so important right now. I worked on some mechanical sealing systems by the way. But this flexible one will be simple and cheaper if i find one.
The speed of the moving object is about 2.7 cm/s.
Thank you all.
I would recommend, seriously, that you consult with Brewnog and Fred Garvin. They both seem to have the most experience with sealing technology. I haven't seen Fred for a while, but Brewski is still here.
(Sort of reminds me of the old joke about the Inuit hunter who got trapped on an ice-floe with his snowmobile after he blew a seal... but I don't think that it's appropriate for PF Guidelines.)
  • · Replies 152 ·
12K
21K
10K
