What is the frequency of a police siren when you run away from it?
  • Thread starter Thread starter ThePhysicsXV
    Frequency
The discussion revolves around calculating the frequency of a police siren as it approaches an observer running away from it, using the Doppler effect formula. The police car emits a siren at 988 Hz while traveling at 23 m/s, and the observer runs away at 7 m/s. Participants clarify the roles of the source (the siren) and the observer, emphasizing the need to consider their motions separately. The speed of sound at 28°C is calculated to be 348 m/s, and the correct application of the Doppler effect formula yields a frequency of approximately 1036.64 Hz as the police car approaches the observer. The conversation concludes with participants confirming the accuracy of the calculations and expressing gratitude for assistance.
ThePhysicsXV
Temperature is 28C, a police car with a siren blazing at 988Hz is coming toward you at 23m/s so you run away at
7m/s.
f=f(v+-o/v+-s)
I'm confuse on the formula.
What specifically is confusing you?
I know how to solve to get the speed of sound but are they moving forward (+) or backward (-) and what's is the observer and source. Is the source the police siren?
Do I use the formula I gave or the one from the picture?
The observer is what detects the sound. The source is what produces the sound the observer hears.
Consider the two motions separately. What effect does the motion of the police car have on the frequency detected, and what effect does your movement have on the frequency detected?
So is V = 988(348+7/ 348+8)
Or V=988(348-7/348-23)?
348m/s is the speed of sound
Instead of plugging numbers in randomly, please answer the questions.
I have no idea how to answer your question.
How would you "solve to get the speed of sound"? The speed of sound is a given.
As vela says, the source is the siren, you are the observer.
Are the source and observer moving in the same direction or in opposite directions?
As vela suggests, try it in two parts. First, what frequency did you hear before starting to run? Can you quote an equation for the Doppler effect?
The source and observer are moving on the same direction since the police car coming toward you, and you getting away.
V sound in air = 331.4 + 0.6T
T is temperature so temp=28
And you will get 348m/s
Ok, but what about the Doppler effect? So far, I see no evidence that you've even heard of it.
Doppler Effect for Moving Source and Observer
ƒ'=ƒ((1±u₀/v)/(1±u(sound)/v))
Ok, so apply that.
haruspex said:
Ok, so apply that to the case where the car is approaching you but you are standing still.
Actually they both moving at different speeds. Police at 23m/s and "you" at 7m/s
Yes, I replied a little too quickly, then edited it.
I anticipated that you would quote a formula for only one movement, so I was trying to get you to solve it in the two stages, as vela had suggested. When I realized your equation allowed for both moving I edited my post, but you were too quick for me.
So, apply the equation.
f=988(348+7/348+23)
f= 945Hz
I did have some concerns about the equation you posted previously, but I wanted to see how you applied it. The equations in the image you have attached look fine, except that you should ignore the references to "Stationary" observer. That makes no sense given the rest of the text. It's probably a cut-and-paste error from some preceding cases.
So, which of the two cases in the image do you think applies here? What do you get when you apply it?
f= f(v-o/v-s)
I got 1036.64Hz
ThePhysicsXV said:
f= f(v-o/v-s)
I got 1036.64Hz
I get the same. Round that to the appropriate number of digits.
Okay, I guess that's the correct answer. But Thank you sir for your help
