selishaphysic
- 7
In an induction experiment a tightly wound solenoid is used to produce a current of 2A. The
solenoid is then unwound to make another tightly wound solenoid of twice the diameter.
What current would you expect to get if you use the new solenoid in the same experiment?
I'm new to this forum and I just learned that I'm supposed to show my own effort here or maybe what I understand. Well here it comes (I'm not very good at physics). I've learned in physics class that the induced emf= number of loops times the magnetic field times the change in area over the change in time. I know that the area will be bigger which will make the induced emf bigger, but what about the current, what formula should I use here? Just by thinking about P=IV I get confused since then I would want to know the power and the voltage. Although now that I think of it more, when the diameter is bigger the number of loops around the solenoid are getting less and the area is getting bigger so it's basically the same. So we get the same current in both. Am I thinking right ?
