What Happens When Two Cars Collide and Stick Together?
  • Thread starter Thread starter ConstableZiM
    Impact
In a collision between an 1800kg car traveling north at 35 km/hr and an 1100kg car traveling east at 45 km/hr, the two cars stick together and skid to a stop. The velocity immediately after the collision is calculated to be 7.7 m/s at an angle of 51.8 degrees. The kinetic energy lost during the collision is determined to be 84,648 J, indicating that the collision is inelastic, as objects sticking together typically signify inelastic behavior. To find the average force during the collision, a force of 14,800 N is calculated based on the collision duration of 600 ms. The discussion emphasizes the importance of distinguishing between elastic and inelastic collisions when calculating energy loss.
ConstableZiM
An 1800kg car traveling north at 35 km/hr collides with an 1100kg car traveling east at 45km/hr. The cars stick together and skid to a stop (a) what is the velocity (speed and direction) of the two cars immediately after the collision? (b) How much kinetic energy is lost during the collision? (c) if the collision occurs during a time of 600 ms, what is the average force between the cars?
Practice exam problem, none given
I get an answer of 7.7 m/s at 51.8 degrees for a, but when I plug that into the kinetic energy equation of K = 1/2(m)(v^2) (initial) - 1/2(m)(v^2)(final), I get a number of 84648 J, even though its supposedly elastic? As for C, I get a force of 14800 N.
Am I doing this correctly? Help would be appreciated
Nobody? ;,[
isn't not elastic. Whenever objects stick together, it's usually not elastic.
what you need to do it calculate the ideal energy (had it been elastic), and then calculatue the actual energy of the system, and subtract the two to figure out how much energy was actually lost
