What happens when two dynamic systems collide?
  • Thread starter Thread starter jhe1984
    Systems
When two dynamic systems, such as storm systems with differing pressures, collide, they seek equilibrium, but do not merge seamlessly. High-pressure systems typically divert low-pressure systems rather than canceling them out, influenced by factors like pressure gradients and jet streams. The interaction can lead to various weather phenomena, including tornadoes and cold fronts, depending on the dynamics involved. In acoustics, sound waves can either cancel each other or combine to form a more powerful wave, depending on their phase relationship. Understanding these interactions requires complex equations and models beyond simple explanations.
jhe1984
When two systems (maybe systems is the wrong word) collide?
This question is presented in a meteorological sense, but I imagine it applies to almost any interaction between two dynamic systems. Any and all examples or leads into this phenomenon (outside of purely mathematics) would be interesting and appreciated...
**My question**
Correct me if I'm wrong, but at least over the continental US two different storm systems (or cells), one having a low pressure and warm air and the other having high pressure and cold air, merge in pursuit of an equilibrium. But what mechanisms guide this interaction and the interactions between any two similar objects moving at each other like pressure cells? I imagine they "cancel out" in some sense, but what rules guide the various aspects of this cancellation like change in velocity, momentum, pressure etc.?
I am not as much concerned about temperature of the air as I am about the interaction between the two different pressures (although they might be related)...
Here's what I think happens:
Obviously, the two systems will seek equilibrium in both pressure and temperature. I would imagine that this occurs in different forms and produces different outcomes (tornadoes, cold fronts, etc), but what I am primarily concerned with is how much the momentum (or maybe its power?) each cell loses as a result of the collision.
Another version of the same phenomena in question,
What happens if you shoot two sound waves of the same magnitude at each other? Will they cancel out or just merge into a 3rd combined form?
Thanks a lot!:eek:
I'm afraid that your question is not to be answered in a single post. Furthermore i't's a tad or 20 more complicated. Highs and Lows seldomly merge like that, it's also got to do with the pressure gradient aloft, jet streams, orography, etc, etc.
Why not try it here? www.ukweatherworld.co.uk
Yeah it's pretty broad/vague. I'll see if I can't refine it. Thanks for the link!
Question 1--simple answer:
Imagine the weather map as a literal topographic map, with the high pressure areas as domes, and the low pressure ones as low whirlpools. This visual model will show why low pressure will always be diverted around or stopped by high pressure; they can't cancel each other out or merge.
Question 1--the better answer:
What Andre said; the actual equations are quite complex, and I'll be the first to admit that they're way over my head; I'm no wxman, just a hobbyist.
Question 2:
From what little I know about sound waves, it's that they behave just like waves in any other medium. If two waves of equal power are perfectly out of phase and meet head-on--the crest of one coincides with the trough of another--they will cancel each other out. If they are perfectly in-phase--the crests and troughs coincide--they will combine to create a more powerful wave. Usually though, they are out of phase just so, so that the pattern of their intensities appear random; IIRC, this can be described algebraically.
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
We have little shade but plenty of wind on my property. The upshot of this is that I have to be judicious in how/where I put up shade-creating barriers in various places around my property to maximise shade without unduly large windage. My property is an irregular polygon and not aligned with the cardinal axes, so it is not easy to tell where the shade will be at a given time. For example, I have put up an umbrella next to our pool, but it can only shade the southish-side of the pool, and...
These last days, there is a seemingly endless cluster of rather powerful earthquakes close to the islands of Santorini, Amorgos, Anafi, and Ios. Remember, this is a highly volcanically active region, Santorini especially being famous for the supervolcanic eruption which is conjectured to have led to the decline of the Minoan civilization: https://en.m.wikipedia.org/wiki/Minoan_eruption To grasp the scale of what is happening, between the 26th of January and the 9th of February, 12000...
