What is 2x10-4cm converted to metres?
  • Thread starter Thread starter Colin_m
Colin_m
what is 2x10-4cm converted to metres?
2x10-5 or 2x10-6?
Thanks
multiply by this conversion factor:
1 = 1m/100cm
it is better for you to familiar with these
cm=10^-2m
mm=10^-3m
um = 10^-6m
nm=10^-9m
It helps you when you calculate...
cheers
