What is a Primitive Cell in Material Science?
In summary, the conversation discusses the concept of a primitive cell in material science and how it relates to crystals. A primitive cell is the smallest unit cell that can be used to build up a crystal through simple repetition. This choice is not unique and there are an infinite number of possible choices, but they all have the same volume. In some cases, a larger conventional unit cell is used to better show the symmetry of the crystal. The conversation also mentions the advantage of using a conventional unit cell for simpler calculations.
raees29
In Material Science, what is a primitive cell when speaking crystals.
Welcome to PF,
Did you try googling: "primitive cell crystal"?
I did but I'm getting confused by the definition of a Primitive Unit Cell and a Unit Cell.
I know what a unit cell is, I wanted to find out what a primitive unit cell is so I can distinguish the 2 myself
A primitive cell is the smallest cell you can use to build up your crystal by simple repetition. The choice is not unique. In fact there is an infinite number of possible choices, but they turn out to all have the same volume.
In some cases like FCC or BCC one often uses a "conventional" unit cell that is bigger than a primitive one. This is done because the conventional unit cell more intuitively shows the symmetry of the crystal.
In the end, if you do your math correctly, the choice does not matter.
Likes Simon Bridge
Primitive unit cell contains only one lattice point while conventional unit cell have more than one point, and as said by M Quack are usually considered for symmetry purpose.
Likes M Quack
That is how is defined in my book. Thus, the disadvantage of using a primitve cell is that how you can only have one lattice point inside of, sometimes you will get a pretty weird shaped cell. If you are more flexible, and if you decide to have more lattice points inside of your unit cell, you can get a better shape. For instance, if you use a cube with for lattice points, you can describe the Bravais lattice of a FCC very nicely. However, if you try to describe this very same lattice with a primitive cell, you will get a very weird thing.
Please, let me know if that helped you. I am also studying this subject, so we could discuss it together in more depth.
You can choose a Wigner-Seitz cell that is primitive and has the full symmetry of the lattice. I think one reason of using conventional unit cells is that it sometimes makes simpler the calculations.
Related to What is a Primitive Cell in Material Science?
1. What is a Primitive Cell?
A primitive cell is the smallest repeating unit of a crystal lattice, which is the regular pattern of atoms or molecules that make up a crystal. It contains the minimum number of atoms or molecules that can be repeated to create the entire crystal structure.
2. How is a Primitive Cell different from a Unit Cell?
A unit cell is also a repeating unit of a crystal lattice, but it may contain more than one primitive cell. The primitive cell is the simplest and most basic unit, whereas the unit cell may be composed of several primitive cells depending on the crystal structure.
3. What are the characteristics of a Primitive Cell?
A primitive cell must have three axes of equal length that intersect at 90-degree angles, as well as three axes of different lengths that also intersect at 90-degree angles. It must also have a unique set of lattice points, which are the positions where atoms or molecules can be placed to form the crystal structure.
4. What is the significance of studying Primitive Cells?
Studying primitive cells is important in understanding the structure and properties of different materials. By understanding the arrangement of atoms or molecules in a crystal lattice, scientists can predict the physical, chemical, and mechanical properties of a material, which has implications in fields such as material science, engineering, and medicine.
5. How are Primitive Cells determined experimentally?
Primitive cells can be determined experimentally using techniques such as X-ray crystallography, which involves bombarding a crystal with X-rays and analyzing the diffraction pattern to determine the arrangement of atoms or molecules. Other methods include electron microscopy and neutron diffraction. Computational methods, such as density functional theory, can also be used to predict the primitive cell of a material.
  • Atomic and Condensed Matter
