What is the Definition and Function of an Electric Field?
An electric field is defined as the electric force per unit charge and is represented as a vector field surrounding electrical charges. It mediates the interaction between charges and is influenced by changing magnetic fields. The electric field can be calculated using Coulomb's Law or Gauss's Law, with units of Newtons per coulomb (N/C) or volts per meter (V/m). It is essential for understanding how charged bodies are accelerated and can store electrical potential energy, which is quantified by specific equations. The concept of the electric field is foundational in electromagnetism, linking it to both electric and magnetic phenomena.
Definition/Summary
Electric field is electric force per charge, or electric potential energy per distance per charge.
An electric field is a vector field that permeates the space around electrical charge. It is what mediates the force between that charge and any other charge nearby. It is also caused (induced) by a changing magnetic field.
The electric field, \mathbf{E}, can be found from the charge producing it (using Coulomb's Law, or Gauss's Law), or from the electromagnetic potential (using \mathbf{E}\ =\ -\nabla \phi\ -\ \frac{1}{c}\frac{\partial \mathbf{A}}{\partial t}).
Electric field is a vector with units of Newtons per coulomb (N/C) or volts per metre (V/m), and dimensions of mass.length/charge.time² (ML/QT²).
It is derived from (non-unique) vector and scalar potentials, \mathbf{A} and \phi (and the magnetic field \mathbf{B} is derived from the same vector potential).
It transforms (between observers with different velocities) as three of the six coordinates of a 2-form, the electromagnetic field, (\mathbf{E},\mathbf{B}), which in turn is part of the electroweak field.
Equations
(1) <br /> \vec{E}=\lim_{q\rightarrow 0}\frac{\vec{F_e}}{q}<br /> =\frac{1}{4\pi \epsilon_o}\int\frac{\rho (r)}{r^2}\hat{r}d\tau
(2) \oint \vec{E}\cdot d\vec{a} =\frac{Q_{enc}}{\epsilon_0}
Potential equations:
(3) \mathbf{E}\ =\ -\nabla \phi\ -\ \frac{1}{c}\frac{\partial \mathbf{A}}{\partial t}
\mathbf{B}\ =\ \nabla\times\mathbf{A}
The two source-free Maxwell equations (Faraday's Law and Gauss' Law for Magnetism) follow immediately by differentiating the potential equations:
(4) \nabla\times\mathbf{E}\ =\ -\frac{1}{c}\frac{\partial \mathbf{B}}{\partial t}
\nabla\cdot\mathbf{B}\ =\ 0
Energy density:
(5) u_e=\frac{1}{2}\epsilon E^2
Total energy:
(6) U_e=\int_{\tau}\frac{1}{2}\epsilon E^2 d\tau
Extended explanation
The electric field, along with the magnetic field, were originally conceived by Michael Faraday to explain the long range nature of those forces. The mathematical development of this field theory was left to Maxwell.
Since the electric field can accelerate charged bodies, it must be able to store electrical potential energy. The energy density of an electrical field is given by equation (5). In order to find the total energy stored in the field, the density function must be integrated over all space, thus giving rise to equation (6).
Time-varying electric fields are somewhat more difficult to find due to the fact that they can be created by time-varying magnetic fields as well as a time-varying potential. This phenomenon, known as Electromagnetic Induction, is represented in the derivative of the magnetic vector potential in equation (4).
After some manipulation of (4), you will obtain Faraday's Law, a much more well known representation of induction:
\vec{\nabla}\times \vec{E}=-\frac{\partial \vec{B}}{\partial t}
Reason for definition of electric field:
Electric field \mathbf{E} is defined so that multiplying it by the charge q of a body gives the force \mathbf{F} on that body:
\mathbf{F} = q\mathbf{E}
This is the electric part of the Lorentz force: \mathbf{F} = q\left(\mathbf{E} + \mathbf{v}\times\mathbf{B}\right)
So it must have dimensions of force/charge, or work/charge.length, and so can be measured in Newtons/coulomb.
Since work (or energy) can be measured in electron-volts, work/charge can be measured in volts, and so electric field can also be measured in volts/metre.
By comparison, magnetic field is defined so that multiplying it by the charge of a body and cross-producting it with the velocity of the body gives the force on that body:
\mathbf{F} = q\mathbf{v}\times\mathbf{B}
Similarly, therefore, magnetic field must have dimensions of force/charge.velocity, and can be measured in volts/metre per metre/second, or volt.seconds/metre², which are webers/metre², or teslas.
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Thanks for the overview of electric fields!
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
