What is the acceleration of the ball?
  • Thread starter Thread starter chrish
    Acceleration Ball
The discussion focuses on calculating the acceleration of a baseball struck by a bat, given specific force and time parameters. The user struggles with determining the average force and subsequently the acceleration, having already exhausted attempts for part b of the question. It is noted that Newton's 2nd law can be applied to find average acceleration once the average force is established. The conversation emphasizes the need to analyze the force versus time graph to derive the average force. Understanding these calculations is crucial for solving the problem accurately.
chrish
thatnks for helping.
ive tried this question all day, and its due tonight. here it is
The force exerted on a 0.145 kg baseball by a bat changes from 0.0 N to 1.0 104 N over 0.0010 s, then drops back to zero in the same amount of time. The baseball was going toward the bat at 23 m/s.
(a) Draw a graph of force versus time. (Do this on paper. Your instructor may ask you to turn in this graph.) What is the average force exerted on the ball by the bat?
________ N
(b) What is the acceleration of the ball?
____________ m/s2
(c) What is the final velocity of the ball, assuming that it reverses direction?
__________m/s
i already used up all my chances for part b, so that one is useless.
i tried finding acceleration using a= change in velocity over time,
but that didnt work. i tried finding the force also, but i kept getting the same answers (3335,2300,11500,-11500,72500.)
i understand the subject, i just can't find the answer. thanks
Since you aren't given the change in velocity (in fact, you are asked to find the final velocity), you can't use it to find the acceleration. But you can use Newton's 2nd law to find the average acceleration once you figure out the average force.
What did you get for the average force? (From analyzing your graph.)
