What is the Center of Mass of a Rod with Varying Linear Density?
The problem involves determining the center of mass of a rod with a varying linear density described by a specific function. The rod's length is given, and the linear density is expressed as a function of distance along the rod.
  • Participants discuss the integration of the linear density function to find the mass and center of mass. There are questions about whether to treat the linear density as a constant and how to apply the relevant formulas correctly.
Some participants have offered guidance on integrating the linear density function, while others express confusion about the application of formulas and the results obtained. Multiple interpretations of the problem are being explored.
There is a mention of differing results based on whether the linear density is treated as constant or variable, indicating a potential misunderstanding of the problem setup. The original poster also notes discrepancies between their calculations and expected answers.
bolivartech
A rod of length 30.0 cm has linear density (mass-per-length) given by
λ = 50.0 g/m + 20.0x g/m2
where x is the distance from one end, measured in meters. (a) What is the mass of the rod?
(b) How far from the x = 0 end is the center of mass?
Xcm = l/2
λ = 50.0 g/m + (20.0)(.3m) g/m2
λ = 56 g/m * .3 m
λ = 16.8 g
Xcm = .3/2 = .15
The actual answers are 15.9 g and .159 m
Am I not using the formulas correctly?
[tex]m=\int\limits_0^L \lambda(x) {\rm d}x[/tex]
[tex]x_G=\frac 1 m \int\limits_0^L x\lambda(x) {\rm d}x[/tex]
Would I consider λ a constant.
m = λ1/2x2
m = (50.0 g/m + (20.0)(.3m) g/m2)(1/2)(.32)
of integrate it as well. Both ways that doesn't seem to be the right answer either. I get 2.43 if I integrate λ, and 2.52 if I don't.
[tex]\lambda[/tex](x) is a function of x that happens to be 50.0 + 20.0x, so you replace
[tex]\lambda[/tex](x) by 50.0 + 20.0x and integrate the result.
This is ridiculously when you put it that way. Thanks, I understand how to apply the formulas now. Hopefully when it gets rearranged for a test I will still see it.
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 29 ·
