What is the Change in Internal Energy for a Cyclic Process on a PV Diagram?
The discussion focuses on calculating the change in internal energy for a cyclic process represented on a PV diagram. The pressure and volume values at points A and C are given as 3 atm, 0.08 m3, and 750 J for point A, and 1.2 atm, 0.03 m3, and 420 J for point C. The key equation used is delta U = Q - W, where delta U is the change in internal energy, Q is heat exchanged, and W is work done. The participant successfully calculated the heat exchanged (Q = 9119.25 J) but struggled to determine the change in internal energy for process abc due to uncertainties about the work and heat in non-ideal gas conditions.
  • Understanding of the first law of thermodynamics (delta U = Q - W)
  • Knowledge of PV diagrams and cyclic processes
  • Familiarity with concepts of constant pressure and constant volume processes
  • Basic principles of thermodynamics related to internal energy
  • Study the implications of the first law of thermodynamics in cyclic processes
  • Learn how to calculate work done in non-ideal gas conditions
  • Explore the characteristics of constant pressure and constant volume processes
  • Investigate the relationship between internal energy and heat for real gases
Students studying thermodynamics, particularly those tackling cyclic processes on PV diagrams, as well as educators and professionals seeking to deepen their understanding of internal energy changes in non-ideal gas scenarios.
uchicago2012
For point A in the figure (See Figure 1), the pressure is 3 atm, the volume is .08 m3 and the internal energy is 750 J. At point C the values are 1.2 atm, .03 m3, and 420 Joules.
(a) For the cyclic process abcda, how much heat is exchanged with the environment?
(b) For the process abc, what is the change in internal energy?
delta U = Q - W
where U = internal energy, Q = heat, and W = work
for (a), I found Q = 9119.25 J because it's a cyclic process, so delta U = 0 and Wnet = the area of the square. But for (b), it's not exactly clear how I'm supposed to find the change in internal energy. I can find W by finding the area under the curve, which equals 15198.75 J, but I don't know U now and I don't know Q either. All I can get is Qda > 0, which isn't particularly helpful.
Do you see what type of process A-B is? And B-C? Realizing what processes those are should help.
I know A-B is constant pressure and B-C is constant volume. Thus, B-C does no work. But I know what the net work is. I need to know the net heat so I can figure out the change in internal energy and I don't know of any pertinent handy facts about constant volume or constant pressure processes. The only useful things about constant pressure processes in my book are for ideal gases, and this isn't an ideal gas. So I don't see what you're saying.
