What is the change in its thermodynamic temperature?
The discussion focuses on calculating the rise of a mercury column in a thermometer as it heats from 10°C to 86°C, with a specific volume of mercury and a narrow bore diameter. The user is seeking the thermal expansion coefficient for mercury, which is identified as 182 x 10^-6/°C at 20°C. Additionally, a related question about the change in thermodynamic temperature for a steel block heated from 10°F to 110°F is posed, with the assumption that the change is simply 100°F. References to external resources like the CRC Handbook and HyperPhysics are provided for further information on thermal properties. The conversation emphasizes the need for accurate thermal expansion coefficients in calculations.
jakeowens
A thermometer has a quartz body within which is sealed a total volume of 0.410 cm3 of mercury. The stem contains a cylindrical hole with a bore diameter of 0.10 mm. How far does the mercury column extend in the process of rising from 10°C to 86°C? Neglect any change in volume of the quartz.
I know how to do this problem, using V=V0(1+B*delta t). I just cannot find the expansion coefficient. can anyone help me out? I've been searching on the web for 15 minutes and i keep finding physics labs and crap, but no tables with values for expansion coefficients.
I don't have the textbook for my class which has all the values in it so I am kinda SOL.
A block of steel is heated from 10F to 110F. What is the change in its thermodynamic temperature?
Is this one as simple as i think it is? Is the answer just 100? that seems way to easy to me but i don't see what else it would be asking.
Consider this - http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/thexp2.html#c3
Thermal expansion coefficient of mercury is 182 x 10-6/ºC at 20ºC
http://www.efunda.com/materials/com...cfm?MatlPhase=Liquid&MatlProp=Thermal#Thermal
Density of Hg at 300K = 13529 kg/m3, and density at 350K = 13407 kg/3.
Data from F. Incropera and D. De Witt, "Fundamentals of Heat Transfer", John Wiley & Sons, 1981, Table A.5, "Thermophysical Properties of Saturated Liquids."
CRC Handbook of Chemistry and Physics should also have these data.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
