What is the correct formula for calculating noise level in decibels?
  • Thread starter Thread starter Drizzy
    Formula Noise
The discussion revolves around the calculation of noise levels in decibels, specifically addressing the formulas used for sound intensity and their applications. Participants are exploring the relationship between sound intensity and distance from the source.
  • Participants are questioning the validity and application of two different formulas for calculating noise levels. There is an attempt to understand the origin of the constant in the formulas and when to use each one. Additionally, there is inquiry about the interpretation of the calculated noise level in relation to the threshold of hearing.
Some participants have provided clarifications regarding the formulas and their equivalence, while others are seeking to understand the implications of their calculations. The discussion is ongoing with multiple interpretations being explored, particularly concerning the context of the formulas and the significance of the results.
There is mention of the threshold of hearing and pain in the context of sound intensity, which may influence the understanding of the formulas. Participants are also navigating the implications of distance on noise levels, as well as the relevance of specific values in calculations.
Drizzy
When the distance to a sound source is doubled, the noise level will be halved. Yes or no?
L = 10 lg(I/10-12) or L = 10 lg(I/l0)
my book used the first formula in another question and it used the second one in this problem. I know how to solve the problem but what I don't know is where 10-12 comes from. Because in the text where my book tries to explain sound they only write the first formula but then when they gave an example of a problem they used the second formula. Which is the real one and when do I use them?
The first formula is the same as the second with l0=10-12 W/m2. That's the so called threshold of hearing
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/intens.html#c3
Both are real and either one can be used to answer this particular question. For other questions, I would say you should probably use the first one if a specific value for l is given. Here it is not, and it doesn't matter that it's not.
If I and I0 are given and I calculate the value of L, what is L giving me? Is it the noise level when the intensity is I or is it the noise level difference from when it goes from I0 to I?
It is the sound level in decibels relative to the threshold of hearing. If you read on the hyperphysics link, the threshold of pain is 130 dB. You can solve the equation for I with I0 = 10-12W/m2 and L = 130 dB, to get I = 10 W/m2.
  • · Replies 28 ·
