What is the difference between these systems of mass
The discussion clarifies the distinction between atomic mass units (amu) and molar mass. While both are related to the mass of atoms, amu is a unit measuring the mass of individual atoms, whereas molar mass refers to the mass of one mole of a substance in grams. The conversation also highlights how to calculate the number of hydrogen atoms using the atomic mass of hydrogen in amu, converting it to kilograms, and applying Avogadro's number as a conversion factor. This illustrates that while amu and molar mass serve different purposes, they can be functionally equivalent in calculations involving the number of atoms in a sample.
ronaldor9
What is the difference between amu (or u) and molar mass? It seems like these are equivalent. Could somebody explain them.
And why is it possible to calculate the number of atoms on hydrogen using this calculation:
[1.00797 amu H x 1.6605x10-27 kg/amu]-1=5.975x1026 atoms of H
Chemistry news on Phys.org
I think amu is the reciprocal of avogadro's number then converted to kilograms, avogadro's number is essentially a conversion factor from atomic mass units to grams. Try converting the amu constant to grams then taking the reciprocal. Then look up avagodros number. So really they can by considered functionally equivalent.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
