What is the electric field and potential difference between two charged spheres?
The discussion revolves around calculating the electric field and potential difference between two charged metal spheres, each with specified charges and dimensions. The problem involves concepts from electrostatics, particularly Coulomb's Law and the behavior of electric fields and potentials in the vicinity of charged objects.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants attempt to calculate the electric field at the midpoint between the spheres and the potential difference between them using Coulomb's Law. Some express uncertainty about the charge distribution after the spheres are touched together and separated.
There are various attempts to calculate the electric field and potential, with some participants questioning the direction of the electric field and the implications of touching the spheres. Guidance has been offered regarding the relationship between potential and charge, but no consensus has been reached on the calculations for the charges after the spheres are touched.
Participants are working under the constraints of homework rules, which may limit the information they can use or assumptions they can make. There is a noted lack of clarity regarding the total charge distribution after the spheres are connected.
mateye10
Constant in Coulomb's Law: k = 9 x 10^9 Nm^2/C^2
1) Two metal spheres are each given a charge as shown below. They are initially placed 30 cm from one another (center-to-center distance). (Qa = -6 x 10^-7 C) (Qb = -4 x 10^-7 C) (Ra = 5cm) (Rb=2cm).
A) For purposes of calculating the electric field in the region around them, the spheres can be considered the same as if they were point charges centered at the middle of the actual spheres. What is the electric field (magnitude and direction) at the midpoint between the two spheres?
B) What is the potential difference between the two spheres?
C) The spheres are briefly touched together, then separated. Now what is the charge on Sphere A?
D) Now what is the potential of Sphere B?
E) Now what is the potential difference between the two spheres?
E = kq/r^2
V = kq/r
A) Ea = (9 x 10^9)(-6 x 10^-7)/(.15^2) = -240,000 N/C
Eb = (9 x 10^9)(-4 x 10^-7)/(.15^2) = -160,000 N/C
Enet = (-240,000) - (-160,000) = -80,000 N/C
B) Va = (9 x 10^9)(-6 x 10^-7)/(.05) = -108,000
Vb = (9 x 10^9)(-4 x 10^-7)/(.02) = -180,000
Difference = -108,000 - -180,000 = 72,000 V
C) No idea. Something with the total charge spread over both?
D) I think I need an answer to C to do this. But still don't know.
E) Same as above. Clueless without knowing how to do C.
Thank you! I really need the help.
E = kq/r^2
V = kq/r
What's the direction?
For (C) When they touch the spheres will both be at the same potential.
The direction would be towards the sphere with the charge of -6 x 10^-7 C, right?
So if the potentials are the same I just use the equation kQ1/r1 = kQ2/r2? I know k and the radii. What would i put in for the Q's?
You would solve for the Q's.
BTW: You do know the sum of Q1 and Q2 , don't you ?
