What is the magnetic field strength on Earth's surface at either pole?
The magnetic field strength at Earth's surface near the poles is approximately 0.00006 tesla. The discussion references the Earth's magnetic dipole moment, denoted as D_0, and suggests using the dipole field for calculations. Participants express uncertainty about equating the dipole moment to the magnetic field strength. A link to additional data on magnetic field orders of magnitude is provided for further reference. Overall, the thread focuses on understanding the magnetic field strength at the poles using relevant equations and concepts.
tnutty
Earth's magnetic dipole moment is D_0
B = ____ G
_u = NIA ; N is the number of turns I is current, A is the corss sectional area
I am not sure, they give _u = D_0, but U am not sure what to equate this to.
Perhaps use the dipole field?
http://en.wikipedia.org/wiki/Orders_of_magnitude_(magnetic_field )
about .00006 tesla
Doesn't give the pole strength, but probably has the data you want.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
