What is the magnitude and difrection of the acceleration?
To determine the acceleration of a 5kg mass acted upon by three forces (20N north, 30N west, and 45N east), one must calculate the x and y-components of each force and sum them to find the resultant force. The gravitational force between a 100kg and a 200kg object, 10m apart, can be calculated using Newton's law of universal gravitation with the given constant. The question about rocket propulsion relates to Newton's 3rd law, emphasizing the action-reaction forces involved in thrust. For balanced forces, the correct answer regarding motion is A) no change in translational motion. Understanding these concepts is crucial for solving the problems presented.
shin777
1. three forces act on a 5kg mass. the forces are 20n north, 30n west, 45n east. what is the magnitude and direction of the acceleration?
- how do I set this up? i am kinda lost on thsi one.
2. what is the gravitational force between a 100 kg object and a 200kg object if centers of mass are 10m apart. g= 6x10^-11 N m^2//kg^2
- this one too.. i don't know how i set this up.
3. describe the forces in terms of Newton's 3rd law that propel a rocket?
- what is this mean? i know Newton's 3rd law is for every action there is an equal and opposite reaction but what is this question asking?
4. under a balanced force there A) no change in translational motion B) No rotational motion C) no inertia D) all of above
- I am guessing it's C?
Any help would be greatly appreciated. It's not like I didn't try. None of this problems were done in class and I can't find similar examples either. :(
1. Calculate the x and y-components of each force. Then add all the x-components together. Do the same for the y-components. You will then have the components of the resultant force. From which you can calculate the acceleration in each of these directions using Newton's 2nd law.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
